Jeff at Gyeon
- Aug 15, 2016
- 83
What's up Guys! Jeff at GYEON Quartz USA here. This post is intended to introduce you to one of the latest offerings in the GYEON Quartz line of Car Care Products: GYEON Q2 Matte.
GYEON Q2 Matte is designed specifically for Matte and Satin Paint Finishes, can also be used on Matte or Satin Vinyl, as well as Paint Protection Film.
Q2 Matte enhances color without changing the finish of your Matte paintwork. Simply put it will not add any unwanted gloss to the finish. Q2 Matte is very easy to apply and only one layer is required. It is extremely hydrophobic and designed for maximum durability on Matte or Satin finishes. Q2 Matte is a true SiO2 based Coating. That means it will offer the true protection you would expect out of any paint coating. It will prevent discoloration and oxidation, protect against chemical damage, and provide UV resistance all while making regular wash maintenance very easy.
The Q2 Matte Kit also includes the GYEON hydrophobic spray sealant/quartz detail spray Q2M Cure Matte specifically formulated for Matte and Satin finishes.
Check out this Mercedes G63 receiving the GYEON Q2 Matte Coating and then find the Application Instructions, a Nissan GTR coated in Q2 Matte from Rory at Proven Automotive Concepts, and a link to the AutoGeek GYEON store where there just may be a limited time sale going on for GYEON Q2 Matte........
GYEON Q2 Matte Application Instructions:
1. Wash the vehicle thoroughly
2. Remove any oils using GYEON Q2M Prep
3. Shake the Q2 Matte bottle before use
4. Wrap your GYEON Applicator Suede over your Applicator Foam Block, both included in the kit
5. Apply 4-6 drops of Q2 Matte on to the Applicator Suede
6. Apply in a think layer on to the paint in overlapping and cross hatching strokes, making sure to install an even layer of the Coating
7. Start wiping the Coating off of the panel immediately after you have completed coverage of the area with a GYEON Polish Wipe Towel. Typically work doors and hoods in 2' x 2' sections
8. Once the entire vehicle has been coated, allow it to dry for 3 hours before wiping down with Q2M Cure Matte. Apply Cure Matte with a fresh and soft microfiber towel. Spray 1 or 2 sprays of Cure Matte directly on to your Microfiber and then work in to the paint. Come back with a clean microfiber towel to remove any excess product immediately
9. The Coating is safe to drive after 24 hours of drying in a controlled environment. You want to make sure that no standing water stays on the vehicle within the first 24 hours. Wait 7 days to wash with a detergent or soap.
Check out this Nissan GTR coated in GYEON Q2 Matte from Proven Automotive Concepts
Be one of the first to get your hands on the new GYEON Quartz Q2 Matte Coating by clicking HERE
