New ride and a question??
pricha00
I just picked up an 02 Civic SiR, at least that is what they are called up here in the great white north. I believe they were just Si down in the states. No matter, old couple that owned it took pretty good care of it however they did allow a few brake dust discoloration stains on the OEM rims. I know they are alloy so how aggressive can I get on these? Meg's all wheel cleaner and soft bristle brush did nothing? Any suggestions?
Pat.
The wheels are likely clearcoated as OEM wheels ... you might wanna try Poorboys Spray/Rinse Wheel Cleaner or Megs Wheel Brightner. Both are extremely strong so follow directions and use in well ventilated area. A brush and sponge for agitation are also good choices. These will remove all brake dust.
If it is only discoloration, then consider using some clay and then a paint polish to brighten them and remove stains as possible. Paint cleaner lotions like Pinnacle and P21S might be another choice. Then use a nice wheel sealant like DP or Poorboys so it wont happen again.
