Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
Solution Finish, the product that brings back black trim, is now available in a convenient kit that includes several essential items to help you successfully restore dull, neglected plastic and vinyl surfaces to like-new condition!
Solution Finish isn't your typical trim restoration product. Solution Finish utilizes an advanced blend of polymers to restore and protect virtually any black vinyl or plastic surface. While most trim restorers are greasy and oily, Solution Finish dries to the touch and provides long-lasting protection against the elements.
The Solution Finish Exterior Trim Kit includes:
- 1 oz. Solution Finish Black Plastic & Vinyl Restorer
- 4 oz. Detailer's Pro Series Cleanse-All Exterior Surface Cleaner
- 20 Pack of Large Nitrile Gloves
- 4 Poly Foam Applicators
- 18mm 3M Scotch 233+ Premium Automotive Masking Tape
With the Solution Finish Exterior Trim Kit, you can take plastic and vinyl trim that looks like this...
Into this!
If you've been looking for a solution to dull, faded plastic and vinyl surfaces, the Solution Finish Exterior Trim Kit includes everything you need to restore plastic and vinyl trim - the right way.
Solution Finish - The Solution To Dull, Faded Plastic & Vinyl Trim
