Newb to Cobra Clay Mitt
01GreyStangGT
Active member
IN the description it says you can use the clay mitt while washing using a "high lubricity" like Wolfgang Auto Bathe.
My question: Can it be used with a rinse less such as ONR? I'm thinking that is probably OK but wanted to know if others use it that way.
Yep, you should be able to use ONR or traditional car wash soap. Just keep an eye out for marring.
I have really only noticed marring once using ONR at the rinseless ratio on Toyota. I don't know if it would have made a difference if I had used it at the recommended clay lube ratio or not. Maybe?
Like stated previous you can use ONR though take into consideration if your paint system is soft, medium, or hard due to the ease of marring etc and also consider rinseless washing first then clay or spray the panel down with water then clay
The recommended dilution ratio for ONR as a clay lube is 1:64 or 2 oz/1 gallon.
