Hey All - New here around these parts, and wanted to ask a couple of questions about machine polishing/buffing. Sorry if these are covered somewhere, but I haven't been able to find them with the search function.
Some of these probably stem from high school when I was given the task to buff out a car (25 years ago) and my training was "Here's the buffer, there's the car, get to work". Needless to say flat panels looked pretty decent, body contours varied, and the "valleys" between the rear quarter panels and the trunk showed some nice burn marks..
For these questions, assume I'd be using a new Dual Action machine (PC, GG or similar). Haven't purchased one yet, but wanted to build up my knowledge/confidence that I can improve upon my past efforts (and prevent myself from creating issues like I had in the past). There are plenty of informative threads on the different models, so unless there's something specific to a model that would help here, no need to rehash that.
1. Do I have to avoid the body lines on the car? For example, most hoods have a "center section" that is at a slightly different elevation than the outsides. For example, look at the mercedes in the link below - there are "valleys" on the outside of the hood (dips down over the headlights and then rises again above the grill), and I know the orbital I used in HS created some burn marks in those types of environments.
http://www.autogeekonline.net/forum/how-articles/31000-how-remove-sprinkler-water-spots.html
2. Will I need to avoid edges of the body panels, for example the line where the hood and fender meet?
3. What about the sharp body lines - for example where the fender goes from being horizontal near the hood and turns down to create the wheel well. Some cars have pretty sharp angle/turn here which would create a protruding edge - any special considerations there with the machine?
4. Any best ways to learn the technique, other than doing it? I'd definitely start with my 2004 Expedition which can use some correction, and would be very leery of jumping to my Jet Black BMW X3 anytime soon.
Also, if there's any additional input/advice you can offer for a newbie, please pass it along as I'm interested to learn and research now in hopes to prevent a "Oh $h1t, I just...." thread later
