Hi everyone, New guy here on the forum and also pretty new to extensive boat detailing. I have owned boats for a long time but as far as protection I have always just applied some wax. I was recently really looking over my 2006 Grady White 300 marlin. I ran my hand on the sides of the boat and noticed my hands had white chalky residue on them. I immediately was off to the local boat supply store to see what I needed.
I explained to the guy at the store what the problem I was having and he told me I had oxidation. He recommended I wet sand the gel coat and then compound and wax it. He sold me some 1000 grit wet/dry paper, 3M compound and some boat wax with PTEF. I knew I was going to need a new buffer so I ordered the Porter cable 7424xp from here at Autogeek. It came with 5 pads. They are the 6.5” pads with the 5” backing plate I believe (It was a kit) After doing some reading on here, I got orange pads for the compound and I got red to apply the wax. The reason I give you this long story is because I have a few concerns...
I have done a portion of the boat and the results are much better than before. The true cream color that
Grady whites have is restored to almost new and it actually has pretty good shine now. However, especially while compounding with the orange pad I have been running into some issues... First, I still see some minor sanding scratches. I have been having some trouble with the pads and maybe that is why they aren’t all being removed? I don’t know if I am using too much or too little product but a few times while running the buffer, I would move the buffer to another part of the section and the pad would leave behind a patch of pretty thick compound on the surface that was almost dry? I would have to wipe it off with a towel.
Also, the pad stops spinning quite a bit. (I put a black mark to check spinning) Could I have too much product on the pad? After I do one section I have had problems with spinning on the second section. I applied no pressure and a good amount of pressure with the same results.
So, before I continue on the boat, I wanted some professional advice to get the best results. Did the guy at the boat store tell me a correct process or leave anything out? Since having those problems with the buffer pad, I ordered a wool cutting pad from here at Autogeek as well to try that instead of the orange pad. Have not done so yet. Which would you recommend?
Sorry for the long post. I am just a little lost and overwhelmed but I am really eager to learn. I am a do-it-yourselfer type of person and love seeing results from hard work.
Any help is greatly appreciated.
