Newby question
mattmann
Member
Hello all. I know most of you probably have read a question like this a dozen times but here it goes. I am completely new to all this and am about to purchase a porter cable da polisher and some pads. I am looking for a "one step" deal for polishing as I will be using it on my 2015 f150 that is pearl white. It has some very light swirls from the factory and that's it so I am wanting to polish those out then seal it. I need something idiot proof and was leaning towards Wolfgang products and sealer? There are about 10,000 products so I wanted to ask you guys with way more experience what you use in this situation and would recommend. My process was going to be
1) wash with two bucket method
2) blow dry then finish with microfiber
3) nanoskin the whole truck
4) wash and dry again
5) polish
6) seal
Any reason that wouldn't work or if you see anything you would change, please let me know!! Thanks in advance!
@mattmann. Hi, if it were me I would:
Wash
Dry with Cobra Guzzler [or similar quality waffle weave] Not a regular microfiber towel
Blow dry just the cracks & crevices after drying with the towel, and not the entire vehicle [because water spots can form in a short time, even on a new vehicle because it's not yet waxed/sealed, resulting in you chasing the spots around trying to remove them and basically unnecessarily rubbing on your paint]
Clay instead of nanoskin [IMO clay is alot more intricate than using a nanoskin, especially on a white car, because you can visually see all the little bits of contaminants you remove as you clay. Using the nanoskin you have to rub considerably harder on the paint in order to fully remove those little specs of contamination.
From my experience, the nanoskin is great at making the paint smooth quickly, but if you really want to get it perfect, the claybar still can't be beat at removing it all. Meguiars clay works great.
No need to wash and dry again. Especially if you're going to polish next.
Polish
Seal
And don't forget to seal/treat/dress/coat, or whatever your method for preserving all the plastic trim on your new truck. You'll thank yourself in the long run that you did it from day 1. Or you can remember I gave you good advice and thank me😃
I did this to my wife's car last fall. But I didn't dry it much after the first wash. Figured I was going to nanoskin it anyway, so any waterspots would be removed then. Turned out great.
5) polish
6) seal
Sounds like the truck is in relatively good shape. My take is this. Initially, I'm not a 1 step guy, but the second step isn't tough.
Ford F-150's have tough paint. I've done a couple but they were dark blue and black and they had more swirls than just what you have described.
I would suggest starting off testing out Meguiar's Ultimate Polish on a white pad and see what you get. If that doesn't cut-it (pun intended) try and orange pad. I bet that does it for you here. If you need a faster cut or it's not working the next step would be to use their Ultimate Compound which truly finishes like a polish. If need be, step up to an orange pad.
I then tend to apply a synthetic sealer and I usually do so by hand, but that's just me. A black pad and product would work too. I like Menzerma but as with all the products, there are lots of really good ones.
Looking at your initial steps, I think you can simplify things a bit.
Wash
Dry with Microfiber - just blow out the cracks and joints to remove water
Nano or Clay it
Finish each panel with a simple gloss enhancer wipe down. No need to fully wash it
Polish
Seal
Good luck, be sure to take pics and post back!
For what its worth to you I keep it even more simple if i am not going to Iron X before claying. I wash first and don't bother drying at all. I then soap up a section at a time with the same soap i used to wash it and then run my nano glove over every panel. Once done with that section i rinse and move on. After i have nanoskinned the entire vehicle it's thoroughly rinsed then dried. Then blow out all tight areas. Basically i only fully dry once.
Thanks so much for the advice guys. I will update with pics as soon as I get my porter cable in and get the time off from my job to do it!
I also recommend Menzerna PL as a sealant. Or Megs Ultimate Liquid wax. Both great sealants for a daily driver.
If you're truly looking for a 1-step, you could try something like HD Speed or Griots 1-step Sealant. "Cleaner sealants" with some cut. Lots of HD Speed fans here.
I'm looking for a 1 step because this is going to be my first time ever using a da polisher and I don't want to get in too deep for my every day driver. Also, on the coatings. I am nervous that I will mess up my sealant. I need to know what the most idiot proof coating is. Ive heard horror stories of people leaving high marks and what not.
With most sealers you don't have to worry about high spots. "Coatings" are another type of product entirely, so we must not confuse the two. Coatings are relatively new tech that typically last 1-2 years per application (and they take a little more "know-how").
Sealants don't last as long as coatings, but sealants do offer much better longevity than traditional "car wax". ***You won't have any problem at all with a sealer.*** They're basically synthetic waxes and apply similarly (often easier than a wax).
So the question becomes... Do you want to polish first with your DA to remove swirls and then apply a dedicated "paint sealant" as a second step?
Or do you want to polish and seal with an "all-in-one" type product (this would be your "1-step").
Both have advantages/disadvantages. If you want to save time, go with the all-in-one (ex. HD Speed). Just like it sounds, it polishes and seals with one product.
If you want a maximum level of correction, as well as a better longevity with your sealer, it would be best to polish first (ex. Meguires Ultimate Compound/Polish) and then apply your sealer (ex. Meguires Ultimate Liquid Wax).
If I was going to go with hd speed, what would I use as a sealer? Does hd make one that last a long time?
HD Speed is an "AIO" (all-in-one). It CLEANS, POLISHES, and PROTECTS (it contains a WAX/SEALER!). So, you can use the HD Speed and you're DONE :)
See these threads:
http://www.autogeekonline.net/forum/auto-detailing-101/95282-hd-speed-wax-sealant.html
http://www.autogeekonline.net/forum/auto-detailing-101/96478-hd-speed-questions-observations.html
http://www.autogeekonline.net/forum/products-guides/90377-hd-speed.html
Wash
Polish
Seal
I think I understand seal. Can you fill out for me what is involved in treat/dress/coat?
In which category or "step" does Wolfgang Uber Ceramic Coating belong? Does this coating require extra "know-how"? If so, what do you recommend for acquiring this know-how? Can I study one of the autogeek DVDs? Would practicing on junkyard cars help? I don't want to waste nice products on junk cars, do I?
Hello,mattmann
I just used Blackfire Total Polish and Seal, it's an all in one. Worked very well plus you get the benefit of Blackfire Polymers.
Treat/dress/coat exterior trim: means applying something like aerospace 303 (or others) on black/plastic trim pieces and rubber (doesn't work well on chrome FYI). Basically, applying trim/rubber-specific protectant/sealer/coatings to plastics and rubber.
THIS!!! :dblthumb2:
I was going to just go ahead and reply... then read down far enough to read this. :iagree:
To the OP...
I'm willing to bet that there are far and away more swirls in that white paint that you realize, FAR MORE. :eek:
It's just hard to see them, but they've been there on every truck I've ever seen, especially if it's been washed by someone that isn't your typical OCD Autogeek type. ;)
Several things come to mind.
1: That paint is HARD
2: You'll need a fairly aggressive pad and compound to fix it
3: You need to IRON-X it along with Nanoskin/claying it!!!
4: If you're compounding it, you might want to do a polish as well. (At least this first time.) :xyxthumbs:
5: Applying a sealant is a fantastic idea! :)
As for your process...
I'd do the wheels, tires, wheel wells first, along with the bumpers.
Then wash it to remove the biggest dirt and rinse.
*you can blow it dry, but don't need to totally dry it at this point*
Then you should IRON-X it, rinse again, then wash while it's wet.
NOW you can Nanoskin/clay it with a splash of CLEAN soapy water on each panel as you go. No need to do it all without rinsing either. Just splash some soapy water on the roof, Nanoskin, then the glass, Nanoskin then rinse that area.
Next the hood, tops of the fenders, tops of the doors, with a splash and Nanoskin, then rinse.
Of course next would be the rest of the fenders, then rinse.
Doors, then rinse.
Bed, tailgate, (one side at a time) then rinse.... etc. etc. etc.
Once it is ALL Nanoskinned and rinsed you can re-wet it and go about blowing out the cracks and crevices. Without any sealant (or coating) on it you'll NEVER be able to blow the paint dry, but you can get over half the water off of it. This is why it was suggested that you get a good drying towel, the Cobra Guzzler is one of the (ONLY) Autogeek towels that I'd recommend, for drying, and they are really good! Don't EVER wipe your towels to dry the surface, because there isn't any lubricity in the water. Just place them flat on the surface, then pat, or rub, you open hand on the back of the towel to absorb the water on the surface. Of course a quality Korean Waffle Weave is also an option. I prefer the ones from Ian in San Diego. There is another one, from the guys up in Idaho, in white, have a normal sized one, and one that is HUGE... but I don't like using it, (don't terribly trust it).
As for a compound and pad combo that'll do that hard white Ford paint.
Meguiar's D300 with a orange Lake Country pad.
Meguiar's D300 with a Meguiar's Microfiber Cutting Disc
By and large... these last few years D300 is my most used product from Meguiar's.:D
Meguiar's Ultimate Compound, again, with either of the above pads. (also doesn't dust)
Meguiar's M101, GREAT compound, tons of cut, but may re
HD Cut, or possibly HD Adapt. I have the latter, and it DOES NOT dust, (neither do any HD products) but be warned that HD products have a VERY different learning curve.
Both of the HD products would be great with an orange LC pad, even moving to a white one with a heavier cut product to finish better.
Menzerna FG400 with an orange (or white) LC pad. It is one simply amazing product that'll cut AS WELL AS finish like crazy (on that hard paint). :props:
Menzerna 1000 or 1500, also with an orange pad, or microfiber pad.... just that they don't cut as well, and for some amazing reason.... might not finish as well either.
And of course Rupes pads and compounds, blue, green, perhaps even yellow, along with the matching color pads from Rupes (both the blue foam and yellow foam as well as the blue and yellow microfiber pads are AWESOME). Those won't come into play here however... that is... unless you're planning on investing in a Rupes machine. SHOULD YOU DO THAT... I'd highly recommend the Rupes Duetto 'kit' along with a hand full of extra Rupes pads. :dblthumb2:
For a sealant... Wolfgang Deep Gloss Paint Sealant 3.0 is a seriously good sealant. Of course Menzerna PowerLock would be a close cousin. ;) For a more affordable, (and available locally) solution... Meguiar's M21 2.0 is a GREAT sealant as well!
Then...... there are the choices of a true AIO.
Meguiar's D151 can, and WILL, do great correction on most paints, as well as leave a sealant after the fact. You can play around with a variety of pads with it to fine tune your level of cut. You can ALSO top the 'built-in' sealant with your choice of polymer sealants.
Menzerna One-Step 3-in-1 is another option.
Then of course 3D HD Speed is an AIO product with middle of the road cut like the other two above. I've not used it, (just have too many others here in the arsenal) but I know it'll react like the rest of the HD products and provide extended working times, with literally zero dusting.
THAT SAID... I've never used an AIO that dusted, and doesn't have extended working times!;)
There are plenty of others... PLENTY indeed. And I've used a bunch of them... but I prefer to compound and seal, just get MUCH better protection (and look) that way. :dblthumb2:
-Wolfgang Uber Ceramic Coating. Hmm... I've never tried that product and TBO I don't know anything about it, so I can't help you there..
-No you don't want to waste good product on "junk cars", because even if you did you'd have to thoroughly clean the trim prior to applying product onto it, and who's got time to go through all that on junk trim? But then again, it's not out of the realm of possibility.. Just keep in mind, not all plastic trim is created equal. What may work great on 1 vehicle may not work so great on another..
I agree^
Just to add to this reply:
Seal - Megs Ultimate Liquid Wax, Ultimate Quik Wax, or whatever your choice of sealant
Treat - Megs Ultimate Black, 303 Protectant, Mothers Back To Black Trim Restorer, etc.
Dress - Megs Hyper Dressing, Megs All Season Dressing, etc.
Coat - Turtle Wax Endura Trim Coat
... Whichever method you choose to go with, it's always a wise idea to start when the car is new so it never has a chance to deteriorate in the 1st place.😉
