AustrianOak82
- Sep 26, 2014
- 324
I am going to be working from a brick and mortar location from here on out vs my house. The only problem with the location I will be at, is there is no drain. I can easily run over to the car wash and wash it with my buckets, etc. but I was wondering if there was a solution to hold the water or channel it out the door. I have a garage door as well as a normal door, but the floor isnt level as it should be to channel water out. Squeeging it wouldnt be an option. The chemical guys mat is probably exactly what I am needing, but it's a little out of my range. Has anyone had the same issue and come up with a viable solution? I'd prefer not to spend the $599.00 if I don't have to! Thanks.
