Noob question?!?!!
Superman0440
If BFWD takes 12 hrs to cure, do you tell your customers to come back the next day to apply wax??
No. I would just use the BFWD. Once the car leaves your hands consider it dirty. The are gonna drive around and comeback to you with a dirty car to wax. You might be able to get away with a shorter cure time before the pick up. I have samples of BFWD but have not used it yet so I can't give you an honest opinion.
Anyone chime in and help him out?
Wax is not required after a sealant, however if they request wax or you opt to put it on, I bet you would find that the vast majority of us do not wait more than an hour or so in between applying a sealant and wax.
If I am applying a coating such as OC2.0 or 22ple, for instance, I will require my customer to leave the car with me over night to allow for the coating to cure for a minimum of 12 hours before the car leaves the garage.
