This particular result looks to be due to the clear material not being applied heavily enough.
Does the surface of the clear feel rough/dusty?
Colour/base and clear require different methods of painting. With a base coat you spray for coverage so building light coats 2-3 times is recommended for full coverage. Once the substrate is covered the base is complete.
Clear needs to be “flowed”. Consider for a minute a pair of reading glasses, the only reason you can see through them is because the material is solid and has been highly refined on both sides to produce the smoothest finish possible, reducing light distortion through the surface of the lens.
The same needs to be achieved with clear. If you do light coats, you’ll end up with a rough and uneven surface that will refract light in all directions causing a cloudy appearance. To achieve a smooth final surface, the material needs to be applied more heavily to form a shiny, wet surface.
The trick is in applying enough to “flow” but not so much that you get runs.
If you determine this being the cause, the remedy will be to sand back the clear to a smooth surface again, prep wipe and reapply a single, heavier wet coat of clear.
Consider looking up “flow coat” or “spraying clear” on YouTube for further clarity.
