Mike T said:I tried the wax this past weekend. Stopped after doing half the car. DO NOT try and apply the wax while the surface is hot and in sunlight. Makes it impossible to remove and its streaks. I ended up topping with AW instead. The first panel I did, I was pleased with the results. Nice shine, and help fill some minor imperfections. As I went on is when I started encountering problems.
detailgod said:alot of products will be hard to remove if applied in sunlight and surface is hot.
nick19 said:I don't have that problem. I applied Souveran for the first time outside in FL weather; went on like butter, came off even easier...
Same thing with sealants... I don't have any problem removing any product from the car. (I buff off my hand btw)
Mike T said:Same here. I've used many porducts that are not supposed to be used in sunlight. I've had success with most of them. I'm not saying the wax is a bad product, I'm just saying it is unworkable in sun and with heat.
We have no garagenick19 said:I agree. I have such limited room in our garage
