ok .. so I am getting faster at cleaning the inside of cars.
But I find what is slowing me down a lot is cleaning the seams where the plastic parts meet on the door panels, dashes, etc. I have a truck right now and you can see the brown dirt/dust in the seams and vents. I started off by spraying the seams and or vents down with APC. I then used a brush to go over the seams and scrub the vents out.
It looked good right after I did it .. however the issue is after it dries all the way I can still see that brownish dirt behind.
I then went to my steamer. I tried the steamer straight and again ... when dry it showed back up. Then I used the APC and brush to scrub and then the steamer to kinda rinse it out. again still didnt get it all out. I am really scrubbing these areas quite a bit too!
This isnt my first time with this issue. It actually happens a lot to me for some reason ... things will look good when I am doing it but after it dries it shows right back up. seams, vents, door jambs in the hinges..etc.
I went over the vents like 3 times and they just do not look clean still.
I watch videos like you woldnt believe .. but I realize that none of them really go over dirty seams and crevices.... they all actually look pretty dang clean when they do the videos so those dont really help
does anyone have any good way to get these parts clean the first time around? If you do I would really like to know because if I can figure out a way to actually get them clean and not have to go back over them over and over it would really cut my time down by a lot.
so just to clear things up. I do not remember doing anything while it was dry like brushing it off first, I might have in some spots. Maybe that is something, remove as much as possible before scrubbing.
Maybe blow it out with a compressor first or use a brush first.
What I think is happening is that after I scrub it and try to dry it, I am not able to dry it all in the seams and it just resettles back in. Maybe blow it out with the compressor while its still wet? Does anyone do that?? But then again I did try to use the steamer to rinse it out too....
Maybe the brush I have sucks .. they are the black boars hair brushes with the red case and wooden handles you can find on amazon.
Thanks again for the help!
