Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
One-Step Compound/Polish vs One Step AIOs
NOTE
The below are accurate to the best of my knowledge, if I've made an ingredient mistake, remember.... it's just car wax man. The below pictures also do NOT include all products in all categories. I wrote this article in about 10 minutes, grabbed some products that I think best fit the categories and took a few pictures. I'm sure there are more products for each category, below is what was close and convenient for me to grab and photograph just to give everyone a VISUAL a a 100% TEXT article is BORING.
Just saying ahead of time - everyone's always so serious.... :bolt:
Examples of true One-Step Compound/Polishes
Examples of true One-Step Cleaner/Waxes
Examples of true One-Step Cleaner/Sealant
Examples of true Primer Polishes
There are now 2 terms that are used to describe One Step Products and both terms as well as the groups of products are very different.
Me thinks I'll write an article. :idea:
So to elaborate,
These 4 names mean the same category of product. These are products that will,
The newest product in the above are the Primer Polishes. These are like a cleaner/wax only instead of leaving behind wax they lay down a base layer of some form of ceramic or quartz or ? ingredient that not only seals the paint but can be the base or foundation for to which to then install a ceramic, quartz, polymer, or ? paint coating. The key benefit is the product is made in such a way that it does not have to be chemically stripped with a panel wipe, (solvent), to remove whatever the polishing oils or agents are, or the lubricating ingredients, of the carrying agents for the base protection ingredients. In my opinion, a somewhat complicated product.
The second type of One-Step are compound/polishes. These are a new innovation in abrasive technology where the product can be used with a cutting pad and in this situation the product cuts like a compound. Or you can use the product with a polishing or finishing pad and now the product abrades like a medium to fine cut polish. One example that I used recently that I thought worked incredibly well is the 3D One. See this review.
What separates an One Step Cleaner/Wax, AIO, Cleaner/Sealant or Primer Polish from a One Step Compound/Polish is that the one-step compound/polish does NOT leave behind any type of protection whereas the other 4 category of products do leave behind some form of protection.
With the first group of product, after application you can stick a fork in the project, call it done and kick it out the door.
With the second group of products, after application you should then use something to "seal" the paint as these types of products will tend to be water soluble and offer no lasting protection against rain, inclement weather, washing or even wiping with a spray detailer or waterless wash or rinseless wash as all of these things introduce WATER to the finish and usually some type of cleaning ingredient and any gloss created by the polishing oils will wear off leaving bare naked paint.
Clear as mud? :laughing:
NOTE
So to elaborate,
- One-Step Cleaner/Wax
- AIO
- One-Step Cleaner/Sealant
- Primer Polishes
- Clean or remove defects.
- Polish to restore and/or maximize gloss and clarity.
- Protect - leave some type of protection behind so after this step - you can be done.
