One Step Polish to my Product Line
KJW Detailing
Good Evening AG's,
I'm looking to add One Step Polish to my product line.
Currently, I have the following:
1. Megs 105
2. Megs 205
3. Menz SF4500
4. Klasse AIO
I know that Klasse AIO is your typical AIO product, but I prefer to top any vehicle polished with a sealant unless otherwise asked by the client. Klasse is an excellent product, but I'm not 100% sold on its protective qualities. I'd like to add a product that falls between megs 205 and 105...a search returned these suggestions...
1. Menz PF2500
2. Megs D151
If you were going to do a single step polish, and then follow with a LSP, which of the two products listed above would you use? Obviously, a lot depends on the vehicle and the hardness of its paint, but in general, which product would you turn to.
Thanks, Kieran
Out of your 2 choices....
D151. I always top with something else because the durability is just not there. A great product for production type work and the price point is good.
With foam or mf or even wool D151 plays well and has some good cut and finishing capabilities.
have you thought about Menz FG-400? That has been my go to one step polish, i would just change the cut of the pad for the different types of paints :xyxthumbs:
menzerna power finish is one of my favorites . has never let me down . good cut and gloss . I have done 2 vehicles now with sonax perfect finish and I like this very well also .
How about XMT 360? I've used this on a couple of cars and have been very impressed with the results. I used a green CCS pad as recommended. Its advertised for 3-4 months of protection too.
Sent from my Transformer using AG Online
I would suggest Menz PF2500, it produces a great finish in one step. It can definitely removed fine swirls but not RIDS, but if the latter one is not your concern, PF2500 can do the job.
Recently did my ride and topped with SNH
Wet Look by ej_bebe, on Flickr
Wet Hood by ej_bebe, on Flickr
I ordered some 3D HD Polish. Hope to be able to try it this weekend. It's supposed to be sun friendly. Not sure about the rest.
I usually reach for PF2500 on soft paints.
For harder paints you can try D300 or SIP. Or even FG400 if the paint is hard enough.
HD Speed is great looking product with a very aggressive cut, but it has some consistency issues in the product itself. I'm switching over to Poli-Seal once I run out of XMT 360.
I ended up purchasing MENZERNA PF2500. Thanks for the comments and suggestions!
