I try to only use clean distilled water for wet sanding. Never saw any reason to use anything else.
The reasons you wouldn't want to use ONR in the sanding process is if you don't want to introduce polymers to the paint that could cause issues with an LSP bonding properly, and or the sanding media you are using, like Meg's sanding discs/pads, has a built in lubricant. Also, maybe there's a chance the polymers could mask some sanding marks and let you see the true results of a sanding step. Most of the things probably wouldn't cause major issues but, you really don't know until you try. So give it shot and see what you think. I have actually used it several times on small areas when I need a lube and didn't have distilled water on hand. It did, from what I can recall, cause the higher grits like 3000-5000 not to cut as aggressively, but that could be beneficial in some cases.
