ONR Dillution Rates.
Demonicus666
Hey guys I was wondering when making ONR Clay lube or ONR Quick Detailer, or the ONR wash can I just get say some empy milk gallon jugs and then make three seperate jugs for the quick detailer, the ONR Wash, and the ONR clay lube? So in essence have three empty milk gallon jugs for three diffeent products already made and dilliuted so they are ready to use whenver I want to use them.Feed back please
yup...just make sure you wash the jugs out very well.... :) ... if you want to be extra o.c.d. about it...just buy gallon jugs of distilled water and put the onr into them...the cvs across the street from me sells gallons for like 99 cents...
This is what I use. Inexpensive, and works very well -
autogeek_1940_82598080
Dilutions are:
For clay lube: 2 capfuls per gallon
For QD: 6 capfuls per gallon
+1 on the distilled water. I buy it by the gallon as suggested and mix it from there. No need to worry about washing out the milk jugs and it's cheap!
It's not capfuls right? But oz... The directions on the ONR bottle state oz. not capfuls. I am pretty sure those caps are not one oz.
Just an update, the Quick Detailer i made with Optimum was distilled water and it is still a blue color, while I made some Optimum Clay lube with tap water, and after a few days it went back to clear color of normal water, is this supposed to happen?
Am I only suppossed to use dstilled water or tap water?
Can the quick lube still be used?
Thanks Guys!
the clay lub should be a light blue...no biggie if it clears out on you...
Thanks alot orngez for the reply and on another note for the Optimum no rinse wash, do I really have to use two gallons to make it? Can't I just use one gallon instead??
You're just gonna have to do some math :)
