drastic_detail
- Sep 21, 2008
- 194
Got some of this on the way and was woundering how yenz use this to do a rinseless wash. Just curious about everyones process.
I am new to using ONR and my experience consists of having done 3 ONR washes on my black Camry. I use the Lowe's grout sponge and lots of Meguiar's Ultra Wipe and Supreme Shine microfiber towels for drying.Next, I'll proceed to wipe the roof with the sponge just as if there was soap and water on the car. Then toss the sponge into the bucket and use one waffle weave towel to wipe the roof down to pickup any remaining dirt. Then I'll use a second waffle weave towel to completely dry the roof.
After washing a section with the sponge, I use one MF to start the drying process, If I see any dirt on the MF at all,
Mike
The glaring weakness in this method is the failure to properly attend to the wheel wells and rim barrels. I haven't found a brush yet that is narrow enough to slide easily between the narrow space between fender and wheel, and while I do wash the barrels with my spoke brush, I haven't figured out a way to effectively wipe off and dry the barrels. It's easier to clean tires and wheels the old fashioned way, I think.
Not to hi-jack the thread since my question does fall into the "How to ONR wash" caregory.The glaring weakness in this method is the failure to properly attend to the wheel wells and rim barrels. I haven't found a brush yet that is narrow enough to slide easily between the narrow space between fender and wheel, and while I do wash the barrels with my spoke brush, I haven't figured out a way to effectively wipe off and dry the barrels. It's easier to clean tires and wheels the old fashioned way, I think.
Cheers,
Al
Thanks for the reply. The ONR presoak sounds like something I will add to my process. I think I will also steal Al's idea of drying the jambs while I am washing that section instead of doing them all at the end of the wash.Absolutely. if you are seeing dirt in the drying phase the paint is not clean. You may need to go over each section more than once. Also, consider using a pre-soak (like spray some ONR mixture over the paint prior to starting) to loosen the dirt. I do use a grout sponge so maybe that is a variable.
As others said, be sure to mix per directions as a minimum. I end up using 2 oz per 3 gallons of water. If you have especially hard water, Optimum recommends using a bit more since the cleaning components will bond with the minerals from the hard water and therefore reduce the cleaning ability.
After washing a section with the sponge, I use one MF to start the drying process, If I see any dirt on the MF at all, I stop drying and go back over the area with the ONR again. Am I being overly cautious in my process? Is the ONR preventing the dirt from causing scratches in your method?
Mike
For wheel wells, I just use a regular household sponge (about 1-in thick, tight wells for me) and wipe down with the residue ONR (or DP Rinseless product which I am using at the moment).
While it wouldn't be high pressure, would using a pump up garden sprayer with just water in it help remove the ONR/dirt residue you can't reach with a towel. Never tried it, but I think I might.![]()
The pump-up garden sprayer is a good idea to rinse off the ONR residue and remaining dirt, but doesn't that just put all the dirt on your garage floor?
