ONR with distilled water
runrun411
Does it matter if you use distilled water with ONR or ONRWW?
If it makes a difference, why?
My water in SC is soft. I use tap water for ONR. I use distilled for UWW + to be on the safe side. With APC concentrates I always use tap water.
If you have hard water I would use distilled water. This way you won't get water spots.
My understanding is that ONR softens the water but I guess you can't be too careful.
I agree with y'all. Im glad my water is soft naturally! ONR does soften water indeed. Some add an oz to shampoo to reduce water spotting!
-Distilled water is water that has been put through boiling and condensation processes (distillation)...
It then becomes what is known as:"Pure water", having no minerals or other contaminates (impurities).
On the otherhand:
Hard/Soft/Softened-Water definitely will contain minerals and other impurities.
Mixing distilled water with one of the ONR products is one way to ensure
a much more impurity-free: 'Washing-solution'.
I had my water tested (have a house water softener) and the supply is still quite hard. This region is supposed over some underground granite.
ph=7.1
Hardness= 10 grains HARD
Total Dissolved Solids= 200
