Onr
Success
Member
I'm a believer!!! It works better than I anticipated. It was my first time using a waterless carwash. It really was effortless and the dirt just ran down each panel. If you haven't tried it, you need to!
Optimum No Rinse is a very nice product and has gained quite a following since its release. I for one was extremely skeptical.....until I tried it of course and discovered it was truly an amazing product.
The winter months in New England can put to the test any paint protection product and wash on the planet then spit them out. Last winter I tested two of these products and was amazed at how well they worked leaving my finish slick and clean.
Care must be taken when applying these products as not to scratch the surface with the grime and grit already there. I found that flooding the surface with this product does a nice job of dissolving and dislodging dirt and debris allowing it to harmlessly run down the panel.
I wash each panel twice. The second application really finishes up nicely leaving each panel squeaky clean...:props:
ONR is a great product, but it is not a waterless carwash. It's a no rinse wash. Optimum also makes Opti-Clean which is a waterless wash.
