Oops - mf paint and mf wheel washed together
irvsmith
The microfiber mitt, towels for the paint and wheels were inadvertently washed together. We won't say how but I am working with the assumption that pretty much relegates the entire lot for the wheels or other purposes. Is this a correct/prudent/recommended assumption for the towels? I can't wash the towels separately and reuse them for their original purposes - correct?
Thanks in advance.
David
Rewash them all together again
Not necessary, but it will make you feel better
I only do two loads...Good & Ugly
The trick is to but enough of each so you can do two full loads
One of the things I wish I had learned sooner is that you should change towels so much that anyone watching would think you were nuts. IMO, there is so little up side to trying to use a towel until it doesn't work, like when removing polish residue. Swap, swap, swap
Thanks allenk4
