Hi folks
Been inactive for long,
Anyway, presenting to you 2 cases in one:
1. Persisting with wiper blades that are long past their prime
2. Using amateur techniques to remedy damage caused by bad wiper blades that have actually worsened the driver`s line of vision
Torn wiper blades or wipers missing the rubber blade edge can often leave deep scratches along with streaks on your windshield. These scratches will be just as distracting as streaks. They will reflect sunlight and headlight beams from oncoming traffic. Scratches will definitely obstruct vision, making driving more dangerous. However, it is important to remember that damage can occur any time a repair is not done correctly, making vision still more obstructed.
Tools & Products
- local APC & towels
- Sonax clay
- Sonax felt pad
- Sonax glass polish
- Makita rotary
- A spray bottle with water
- Menzerna Powerlock sealant and applicator
Process
- wash and clay the glass
- tape all rubber trims and cover adjacent areas
- mist the felt pad with water
- apply the polish to a small section of the glass
- proceed slowly to prevent heat build-up. every now and then, spray water on the surface being polished
- check your work at all times, it may require quite a few hits
- be patient and check the temp regularly
- clean and apply a sealant, let cure and wipe
Letting the pics speak:
Front glass: water spotting and swirls
water spots removal gone from bad to worse
swirled glass
close-up of damage caused
can u see through?
The result of using inappropriate products, tools and techniques to remove wiper scratches
From inside.....clarity or a lack of?
closer
Worse still, during a rainy day or night when facing headlight beams from oncoming vehicles
Close-up: wiper scratches have been left intact while new scratches have been instilled
Rear glass: heavy water spotting from acid rain/ wrong maintenance
Close-up
TA DA
Sealing the whole work
Sealing for a wiper free drive
Wiping after curing, we`re grateful to Almighty, all scratches gone and clarity restored
Mirror, Mirror! Where are the water spots
Can you see through?
Thanks for viewing. Your thoughts and questions are most welcome
Zaid
Tools & Products
- Sonax clay
- Sonax felt pad
- Makita rotary
Process
swirled glass
can u see through?
closer
Close-up
TA DA
Zaid
