Want to try prerinsing with ONR when washing my daily drivers via the two bucket method with car soap.Especially this time of year when they get driven on slushy roads etc.On my other vehicles I do rinseless method with ONR but they don't come out in Winter.
Anyway would like to hear opinions on spraying the ONR on the dry/soiled vehicle and letting it sit for 5 minutes then rinsing with the hose then proceeding with the contact wash. Or rinsing with the hose first then spraying the ONR with a pump sprayer, letting it sit for 5 minutes, then proceeding with the 2 bucket contact wash without rinsing with the hose again.Also I was considering using a 1/128 ratio for the ONR and if I chose to rinse the car first with the hose and sprayed the ONR after the car was already wet that 1/128 ratio would be getting diluted down further because the car is already wet.
The two opposing points I see are the following. If I spray the dry car first with the ONR it will loosen some of the dirt and that will be somewhat eliminated by rinsing with the hose afterwards. Or if I rinse the car first with the hose then spray the ONR prerinse it will leave some additional lubrication on the paint to help against making.
To add to this I am not inclined to getting into foaming the vehicles first or even though I have one I don't want to go through the hassle of getting out my pressure washer and then having to put it away afterwards. Trying to keep the process as simple as possible but still getting a half decent wash out of the process.
