OPT polish and compound compared to 106FF and IP
Thejoyofdriving
How much stronger is OPT compound than Menzerna IP? How much stronger is OPT polish than Menzerna 106FF?
Bump................................................................
I would consider OP and IP to be about the same in polishes. You will be able to work the OP longer however. 106FF is very hard to place as its a super abrasive designed to quickly repair the harder ceramiclear coats, yet finishes down into one of the best final polishes ever. Menzerna clearly knows its abrasives ....
