Opti-Coat Application Question
Biff Webster
After applying Opti-Coat 2.0, how long does it take to cure? How long do I need to wait to drive the car afterwards?
The coating will continue to cure for a while... weeks.
You should be OK to drive the vehicle after 12 hours or so, but the longer you can let it sit for the initial curing process the better IMO. I would not wash the car for a week or so after the coating has been applied, but it can get rained on without any adverse effects.
:iagree:
If you do have any high spots make sure those were removed as well.
Awesome, thanks for the info guys. I have some Wolf's Hard Body but I cant decide if I want to use it or order some OC 2.0.
