Opti coat help
BrianMcLeod
I am correcting paint and I was wondering when I am done is the fine is I give the car a IPA wipe down apply black label paint sealant and when ever I get opti coat in can I apply on the black label sealant
No, OC needs to be applied to a clean surface. You should polish the car then do you IPA wipe down then apply OC
Is it fine If I polish the car then wait a week because I am ordering it Friday?
You CANNOT put opti coat on any wax or sealant. The paint needs to be free of all polish, wax, and oils before applying opti coat. Using your steps, after you do a IPA wipe down, that's when you apply opti coat.
Sent from my SM-N900V using AG Online
Beat me by 2 min lol
Would it be fine if I use m205 and a week later wash it and IPA wipe Down
You would have to wash/do a IPA wipe down before again.with This you have a chance to instill swirls. If you're super careful during the week while driving, a simple wash and IPA wipe down and your good to go.
If you won't be driving it and keeping it in the garage. I would do a RW to take any dust off, then an IPA wipe down.
Ok thanks I will probably be really careful two question what is rw? And what does IPA stand for and the perchance of alcohol matter
Here you go:
[ame=http://www.youtube.com/watch?v=nvj80cB2HLc]Opti-Coat 2.0 Application - YouTube[/video]
I prefer CarPro Eraser over IPA. It has more lubricity so is less likely to mar the paint than IPA. Just my $.02!!
Better yet, use Optimum Hyper Polish. After polishing, just wipe off the residue with a damp MF towel and go straight to Opti-Coat 2.0. There is no IPA wipedown needed.
M205 has a lot of oils which may be difficult to fully remove. I would advise doing a degreaser wash with Optimum Power Clean (3:1), followed by an IPA wipedown. Unfortunately, this will leave the surface quite grabby -- but you have no other choice.
