crxman2010
- Aug 25, 2011
- 295
So I am getting ready to remove my wheels this weekend and Opti-Coat the wheels but have a couple questions.
First off for cleaning the wheels, I am going to start with Opti Power Clean at a 3:1 dilution, and go stronger if needed. They aren't very dirty with only 80 miles on the car. If the OPC gets everything off the wheel, do I need to follow up with anything else to prep the wheel for Opti-Coat other than a good rinse? I have read mixed reports on whether or not OPC can be used instead of IPA solution or Griots Paint Prep.
I have read that you can reuse the applicator and MF towels if you clean them before allowing them to dry. Can I just use 3:1 OPC, strong mix of OPC, or something like DP Pad Rejuvenation?
Going forward, when I wash my vehicle, would I need to worry about getting OPC 3:1 or straight OPC on the wheels when I am scrubbing the tires? From what I have read, this will cause no harm but wanted to double check.
I have yet to decide whether or not I will put Opti-Coat the paint, and the reason I am debating it is being able to wax the car later, for looks and relaxation
. In the winter the car is a daily driver but in the summer it is normally a garage queen of sorts.
Anyone have experience applying Opti-Seal or something like P21s carnauba wax or Liquid Souveran over OC? When it is said wax won't last as long over OC, are we talking about first rain, half as long, the product is going to wipe off completely upon being buffed??
I really like the idea of adding an extra hard coat to protect the paint but I also enjoy putting different LSPs on the car when it is sitting around looking pretty.
What has been anyone experience with OC over chip guard? How does it look? How does it hold up with the soft center between the clear coat and OC? My entire Front end has a clear bra to avoid seams in areas with no body lines (full bumper, hood, fenders, and rockers...) and from my previous car, this stuff swirls very easy, easier than Acura's paint.
And I do have any question on actual application, when dealing with something like a roof where it has to be worked from both sides, how do you deal with it? Do as much as you can from one side and move to the other side immediately and overlap?
It will be my first new ride since inhaling to many wax fumes (detail crazy) if you were to ask the wife so any thoughts are appreciated.
Michael
2012 Acura TL Graphite Luster 6MT AWD
Michael
