In the context the the term
Pad-Dependent
Is being used, it means you can adjust the gentleness of the product or the aggressiveness of the product by adjusting the gentleness of your application pad or the aggressiveness of your application pad.
In this thread,
If you look at the paint on the hood after I compounded it with a wool pad using a rotary buffer there are buffers swirls or holograms in the paint. I purposefully showed this in the thread because this is normal and to be expected when using a compound with a wool fiber buffing pad on a rotary buffer.
What I didn't show was I could use a foam polishing pad with the exact same compound and leave a virtually swirl free finish just by changing the pad material.
The demo was to show a two step approach using a "System Approach", but you can modify your approach anyway you like and you can do this by substituting different pads for different procedures to get different results.
Make sense?
- Hyper-Compound is a SMAT product
- Hyper-Polish is a SMAT and DAT product
Any product's aggressiveness or GENTLENESS can be and IS affected by
Application material - Foam, Wool Fibers, Microfibers, Comb wool fibers with foam, synthetic yarn, cotton, cheese cloth, SOS pad if you really want to get aggressive, (just joking)
Application process - By hand, with a DA or Rotary Buffer or a Chain Saw if you really want to get aggressive... (just joking)
While all products are affected by application choice and application method, SMAT products offer a wider spectrum of of ability since the abrasives don't break down and you can stop buffing at anytime during the process.
