SeaJay's
- Aug 2, 2010
- 3,070
I apologize for the late review of this product. With the holidays, a death in the family, and the flu I've been busy. So I finally got around to testing out the product.
I attempted to shoot videos with my IPhone 4 but they came out awful and I can't edit them cause I don't want to spend $30 for Quicktime Pro. So I'm left with my pics again. Oh and my swirl finder light decided to stop working....so I made do with what I could get.
This Equinox is my girlfriends car which I have been lacking on the maintenance. I did a full correction on it last year with a few remaining RIDS. The paint isn't very bad, but some light swirls.
I taped off her hood in 6 sections. The top section being used for the Flex PE14-2 rotary and the bottom for my PCXP.
I tested out the GPS against Poly-seal and Pinnacle SMT 360. All of which are all-in-ones.
I did the first section with the PC and GPS...sorry for the bad pics.
Then I did the top section with the Flex and GPS
Next section I did with Poly seal and the DA.
And Finally XMT 360
Overall opinion is that the GPS is very similar to Poly-seal. Both are a joy to work with in regards to working time, ease of use, and buff off. The GPS is definitely much easier to remove from your pads. Which leads me to believe that the durability may not be as good as poly-seal.
The glaze aspect of it (sorry the pics didn't come out) is not as good as a dedicated glaze (which I expected). It does fill and darken a little bit but not at a lot. This is when I used it as a glaze. Per the instructions I sprayed on the section and took a pinnacle foam applicator and spread it out evenly. Allowed it to haze and then buffed off. I personally do not use glazes very often (closer to never) so this was merely for testing. I would stick to a dedicated glaze if I were to use one.
The glaze does not seem to fill in anything when you use it as a polish with either a DA or a rotary. After polishing out my 2 sections I did an IPA wipe down. Both remained the same with no change.
The spray bottle that the GPS came in I do not like. This is the first time I had used a spray bottle for my polish. The trigger tends to get stuck and I have to wait for it to pop back out. Even after loosening the cap some to let it breath it still did this. The spray pattern was all over the place and not very uniform. If I was too far away I got spray every where, if I was too close it didn't spread on the pad. I finally found a good distance which worked OK. The polish still came out in a small stream at 1st. Which when it hit my pad would splatter. I will be transferring it to a squeeze bottle the next time I use it.
Pros:
Ease of buff off
Good cut for an all in one
Fairly easy to remove from pads
Slight darkening/fill effect when used as a glaze
Cons:
Spray bottle
Lack of durability (?)
The lack of darkening/filling when used as a glaze
Honestly, I didn't see a real noticeable difference in the GPS over the poly-seal. The main differences I noticed were the color and scent. Other than that you probably could have given me either and I couldn't have told you which was which.
And to compare to the XMT 360 - Poly-seal and GPS both have more cut than the XMT 360.
Thanks for reading!
And Finally XMT 360
Pros:
Ease of buff off
Cons:
Spray bottle
Thanks for reading!
