vaca22
Member
- Feb 12, 2020
- 388
- 3
Hey all, after much research I've decided to give OHP a try, but I really wasn't sure what kind of pad to use. I guess my questions have mostly to do with pads rather than the OHP product itself.
The pad they suggest is a waffle pad available from the OPT website. Is this specific pad actually necessary? I dug up a box of used Lake Country pads from WAYYYYYYY back in the day....like 2008 or something crazy like that. They need to be washed/cleaned, but that's another story... My understanding is that OHP can have varying degrees of leveling ability depending on the pad that is used.
Next question - I happened to stumble across small, privately owned auto supply store. I was there specifically to see if they had clay, and noticed they also had a bunch of pads. None of those pads were Lake Country pads, but some other brand such as SM Arnold, Ardex, and HI-BUFF. This distributor seems to carry many Ardex products, in huge quantities that apparently are used by local body shops.
There is a lot of info out there on LC pads, but what about other manufacturers or brands? Is there a brand or type of pad that I should absolutely avoid?
Thanks!!
Thanks!!
