Optimum Leather/Protectant Plus
armorrig
How's it going everyone?
Just have a question for anyone who tried OPT leather protectant that came in the spray bottle.
Does it spray in a wide pattern or is it more of a stream? I have the gallon and using a spray bottle, is the consistency of the product what's causing it to just stream out?
Thanks.
Mine streams more the "sprays" but doesn't bother me because I apply to an applicator first then wipe onto panels or seats
Thanks! Good to know. I was about to buy the 17oz bottle version just to see if it will somehow "spray."
Thanks.
It wont mist. It is too viscuous.
:iagree: But I really like that it can be sprayed on an applicator then applied to the surface you are working on. I don't like spraying products like this directly on the surface anyways. So for this reason, the spray certainly beats pouring or squeezing product out of a bottle IMO.
IMO the stuff is too thick as it comes, you can cut it with a bit of water and get good results.
Thanks Jim for completing the thought! I 100% agree!
I never spray OPP onto the surface. I just use a MF app. Spray it onto the app and then wipe the surface.
Same. I've got a couple of mf mitts that are perfect interior applicators.
I also don't spray OPP directly on the surface. I was just wondering if it was supposed to spray in a wider pattern to have better coverage on the applicator with one squeeze of the trigger... but I can live with the way it is.
:iagree: :detailer:
