Optimum No Rinse as a detailer?
Beerwulf76
My ONR arrive today,and I was super eagle to try it out.Initially I wanted to test it out as a detail spray. I mixed 2oz. with 32oz. of filtered water in a spray bottle.First tested it on panel that was washed yesterday with Meguires Gold Class,before application the panel was squeaky clean and bone dry,no slickness whatsoever. I proceeded with the ORN detailer solution application.Immediately I noticed that it didn't have the feel of a QD'er,no apparent lubricity,like if I just had sprayed the panel with plain water.Then I wiped the panel down with dry side of MF towel and tested for slickness,but it still felt bone dry and squeaky.
So I moved on to my other vehicle,which I had just Quick Deatiled with EO wipe n shine just yesterday that leaves the finish slick and shiny.I prayed the ONR detailer wiped in typical QD'er fashion and tested for slickness.To my surprised the ONR QD'er removed the slickness previously applied by the other QD'er.
I have gone from being excited to rather disappointed!
Anyone have similar experiences with ONR as a detailer?
What gives?
I believed I followed the directions correctly,and according to Optimum's marketing it should have left the finish slick and shiny,like it was just waxed!
Here's Optimum's description for ONR as a QD'er:
Add 8 ounces of No Rinse Wash & Shine to a gallon of water to make an excellent quick detailer. Fill up a spray bottle with this mixture and use it to clean and shine your vehicle, just as you would use a traditional detailer. The proprietary polymers bond to the paint surface to protect it from abrasion and micro-marring as you clean. The incredible formula leaves your vehicle extremely slick and glossy, like you just applied wax!
Feed back please
I never tried it as a QD. I am intereted to see others answers here.
I'm not a big fan of ONR for a QD. Love it as a claybar-lube, and for the few no rinse washes I do.
As a QD it does clean well, but I feel no slickness from it.
Maybe we are both using it wrong?
Im the MAN
If you want slickness then I'd suggest you use a waterless wash concentrate to mix up your QD instead of a rinseless.
I've only used ONR as a water softener, clay lube and for rinseless washing (happy with all uses) so can't say what it does at QD dilution.
Perhaps you should try mixing it again using distilled water. If there were any minerals in your filtered water, then some of the polymers would bind to them leaving less available for your paint?
If it doesn't work then you've got some good clay lube for future use.
ONRs weakest point is as a QD. I despise it for that purpose. Works awesome as clay lube and rinseless wash though.
Try UWW+ for a cheap QD.
The only time I use ONR at QD dilution is when I use it to pre soak my car before rinseless washing.
I have mix of ONR I mixed up as a QD a month ago and I had the same impression that others have. Not slick feeling at all which made me worry about it's ability to clean a dusty car without marring. I'll probably just add more ONR to it and turn it in to a clay lube after I run out of the other clay lube I have.
Im the MAN
How can it be a good clay lube without the slickness?Seem kind of contradictory.
I think he means that it gives good lubrication(in my experience it does) and when he uses it as a quick detailer, it doesn't leave a slick feel behind on the paint. :xyxthumbs:
you don't want your clay lube to be super slippery otherwise the clay will tend to hydroplane over the paint. Some people even use plain water or window cleaner as clay lube...
hmmm maybe that is why the Dodo juice Born Slippery clay lube contains cleaners to help loosen up the dirt so the hydroplaning effect isn't as detrimental to the claying process...
Actually you'd need to dilute it to get the clay ratio. QD ratio is 1:16, the clay ratio is 1:64. I think the QD dilution has the ONR lubricity for cleaning, but because it's designed primarily as a rinseless it doesn't have the nice slick finish additives of a pure QD.
Don't forget when you're using it as an actual rinseless the ratio is 1:256 so the QD is quite a bit more lubricated than what you're doing a rinseless with. I'd say if you're that worried, spray a bit more than a light spray, but that's my amateur opinion :D
The Ultima stuff was what I really wanted,but due to budget I settled on the ONR.I will purchase the UWW+ in the future and use it as QD'er concentrate and the ONR as rinseless wash.My concern though is that if ONR offers no slickness or shine as a QD'er how can it as rinseless wash with the dilution ration being 1/16 of that as QD'er!?
Ahh, good call. I think the soaking MF towel part is what I'm okay with when doing a rinseless wash.
Eh, probably not the best route, but I just use the same mf chenille wash mitt as when I do a normal wash. I've been debating picking up the blue grout sponge with the cut square pattern though for rinseless.
I actually really like it as a quick detailer. Works nicely in the sun and leaves the finish streak free unlike many other products. It's also dirt cheap as a QD compared to a dedicated QD.
I wasn't thrilled with Optimum as a QD either. It cleans the paint and leaves a nice finish, but doesn't really add any slickness.
UWW+ is awesome as a QD. It's my favorite detailing product to use at the moment. It cleans nicely, doesn't streak or smear, and leaves a decent slick finish. It may not be as slick as a traditional QD, but the ease of use and versatility make up for it
I use ONR as a clay lube (2:1) and a QD (10:1). I don't mind that the QD does not have slickness since I use a spray wax once the car is clean, specifically OCW.
I've used ONR as a QD, and while it does clean well, I agree that it doesn't do much for slickness or looks. I've since switched to UWW+, which I feel is a better QD than ONR in every fashion.
2:1 and 10:1? Seems a tad over-concentrated - clay lube dilution is 1:64, and QD dilution is 1:16.
My favorite "slick" QD has been OID. It almost seems to have slight filling properties (hid a few light swirls on me when claying and then went on to give it a touchless dawn bath, revealing the swirls). Plus, it smells like coconuts too IIRC (because lets face it, that's what *really* matters anyway).
:whs:(sorry for the delay, I was at work)
I'm not too concerned with how slick-feeling clay-lube leaves a surface, as long as the surface is smooth after claybarring. ONR keeps the claybar from rubbing against and marring the paint too much, and allows the bar to lift up and grab most of the contaminants in the paint.
If I do claybar, I at least intend to polish the paint to get out the micro-marring the claybar may cause. This is why the slick-feeling left after claybarring would not matter.
Sorry if my first reply caused any confusion.
