I tried it. I dont like the look and there's no durability
that too bad you didnt like it...
what dilution did you try and how did you apply it...
i found the first time i used it i wasnt over the moon, but did more research on it and found some different application methods and now i really enjoy it.
come to think of it, i believe it was my first OPT product in my line up, and now i could without a doubt exclusively use their line up.
i found it also worked great at 1:1. my best application i found was to ensure the tire is clean (preferably dry, but it is water based so not a big deal if a bit damp), and i sprayed in on in a simple pray bottle...i found it to have a nicer look when i sprayed it on, let it sit, and wiped away the excess. i do not like a wet sticky looking tire, just clean and matte finish. I have also used it on exterior plastic trim (before i opti coated it all) and it had a greater durability than any other water based trim protectant i previously tried.
if thats not dark/wet/shiny enough for you, you can also apply a second coat...and i think you may have a different impression if you give it another try.
