brian45acp
- Apr 9, 2012
- 90
Does using the swirl remover products with the PC knock down the orange peel that is in the clear coat?
I have a Tundra and when you look at it from an angle you can see the orange peel. I guess that makes another questions as to how thick these clear coats are to allow for paint correction? I dont intend to use the swirl removers often at all and know that the least aggressive product is to be used first but at what point could someone just keep using those products before going through the clear coat? I would imagine the orange peel is going to add quite a bit of thickness before you even come close.
