I doubt this general detailing advice would apply in this case, because 1. plexiglass scratches relatively easy (well, at least compared to polyurethane clear coat anyway), so most scratches will be relatively deep, and 2. plexiglass is not only around 100 microns thick (like car paint), but at least 100 times thicker - so, it doesn't matter much if you're abrading even dozens of microns, because there will be still plenty left.I would think it would be like anything else, start with the least aggressive.
I mean you can still start off with the least aggressive method first - but it wouldn't make much difference anyway.
My neighbor once asked me if I had anything that could polish up the instrument cluster plastic aka plexiglass that he had removed from his old Ford Bronco [I’m not sure what year but I’m guessing it’s like a 76’. Real big truck]
So I came over and brought along my HF DA with a 3” Orange Lake Country Flat Foam Cutting Pad and some McKee’s AIO Headlight Restoring Polish since afterall it is plastic.. I let him do it himself and he had never used a polisher in his life but the results turned out perfect! Got rid of all the fine swirls and left it crystal clear like brand new. I was almost jealous. Lol.
That McKee’s AIO Headlight Restoring Polish works great on plastic, and I wouldn’t hesitate to use it on that plexiglass you’re dealing with.
I have used regular paint polishes and compounds on plexiglass windshields on motorcycles and boats many times. Not really all that different from trying to clean up a headlight that you don't want to do the whole wet sanding routine on.
Plexus or M37 Plex-All on a like 4" white pad is a good way to finish it off. That also works well on the soft rear windows on convertibles. You can't really remove much scratching because you can't put much pressure on the soft plastic window, but it does a good job removing the yellow tinge that those windows suffer from. You can also use it on the interior side of that window if you can reach it.
Suddenly, the wool pad started slinging and the lens surface had a massive melted gouge in it. OOPS!!! I pulled out another wool pad and tried to clean it up. OOPS!!!
Tossed both goggles into the trash and immediately ordered new ones on Amazon...end of story. LOL!!!
