sudsmobile
- Jan 10, 2018
- 970
- 2
After a while of working out of a full size SUV with a hitch carrier, we finally took the plunge and purchased an enclosed trailer. Got it used with one trip on it for a pretty good price.
I built pretty much everything from scratch. The water tank is 100 gallons and sits in a pocket created from 2x12s and 2x10s. The cabinets I built from 1/2" birch play with cherry face frames. The baskets are held in a 1/2" lip on the face frame. The bottle holders are made from 3" ABS. I'm going to add 5 more but I ran out of ABS.
The pressure washer is mounted on an isolation plate and we take that out and place it on the ground. The generator is mounted to the floor and the exhaust is vented through the side and comes out in the wheel well so totally invisible. The floor was reinforced with 1/2" OSB and carpeted.
The MyTee is strapped to the floor. The vacuum kind of press fits in that area.
The pump is a ShurFlo on demand that feeds a Y for the pressure washer and a hose to fill buckets and bottle. We use only spot free water.
The trailer has it's own Group 27 marine battery installed and I installed a 6 pin trailer plug with a dedicated 12v + and - to help keep the battery charged when we drive. I ran power down both sides to the front and installed an LED light on the left wall. I'm installing two LED light strips on the roof. All will be controlled from a panel mounted on the side of the cabinet by the door which will have a voltmeter, 12v cig lighter plug and 2 USB ports for phones. A switch there will turn the entire panel on and turn on the pump. A switch of the button off turns off all power to everything mounted in the trailer.
Not done yet, but getting pretty close. I have to install a bunch of hooks, holders for brushes, etc, etc.
