Overspray removal questions
jonn127
Is overspray always going to be visible to the naked eye? I removed some from a clients car today and they felt I didn't get all of it, cause the panels that I didn't clay still felt a little rough.
This guy has had the truck 4 years and is convinced the only reason some of his panels are ever so slightly rough, is due to overspray and nothing else. Has nothing to do with the fact he works at a large industrial complex.
It could be a wide range of contaminates. If the surface is not smooth then I would have to agree with your customer. Why did you only clay certain panels?
Overspray is not always visable
Sounds like a learning experience for me on this one. My thought was remove the overspray I can see. So you think I should change to maybe an entire car clay package when there is an overspray issue, no matter how small the contaminated area may seem?
My problem was him thinking his entire truck was smooth as glass before his truck got oversprayed. That might be a problem on my end though. Bottom line guess is I thought I did enough to remove it and it sounds like you are saying I didn't. Should any overspray removal package include a complete vehicle claying?
Absolutely! Overspray has no boundries. You'll usually find one area of the car affected more then the rest, but yes the entire car should be gone over
I would call your customer tomorrow and try to make it right
Overspray Removal is a tedious process. It's real easy to under bid a job
Underbid I did. I appreciate the feedback.
You did such a good job of removing the overspray (and making the paint super smooth) that the rest of the car that didn't have overspray is now crap, tell that to him.
Greetings,
I know what you are talking about... I had 2 customers complaining about wipers blade 'jumping' after coating the windshield; (complaining but in a good manner, I always tell to 'call me if you notice something different because I warranty my services).
2 out of 2, after many tests (and even (at the first case) re-polishing and coating re-application), we had to switch wipers (which were thrashed!), nothing related to coating...
But what happened different? The coating app. Wipers were the same from when they bought the car!
For the second one I went direct on the wipers, switched with mine for testing (was compatible) and no jumping... Ohhh life.
The wipers were still 'jumping' before (I'm 100% sure), but people only start noticing after you let their car's flawless... The 'small problems' starts to appear when you get rid of all the big stuff.
Imagine, I thorough clean the glass, clay it, polish it, use a cleansing polish then coat with a very slick substance.
Learned the lesson, first thing I test when start washing are the wipers. Today was no different, I've tested before starting and customers wipers were 'jumping' - but test was conducted in front of him to avoid any misunderstood later. I've advanced: maybe we'll need to switch those to a new one...
In your case, you also learned a lesson. You should have done some 'bag test' on different areas and showed him how harsh surface really was.
Another thing I do a lot is taking pictures of swirls and scratches when car arrive, 'as it is', so I can also avoid anyone saying I've done any damage. I remove swirls and scratches, not install them!
Back to your thread, overspray removal is a simple task, but can be a complicated task, if not almost impossible task in some cases.
For you to give a precise quote for this job (to do it thoroughly and well done), you have to test a spot in front of customer.
Waterless wash some area, and clay it. At this moment, try to emphasize the 'number of passes' needed to remove the overspray you will be dealing with, also be aware of any paint marring your claying may leave - that will need (generally) to be followed by polishing.
If followed by polishing, you'll need to add some protection after work is done. This demonstration will be more than enough to convince customer how much $$ costs a work like this.
Then you tell him/her: I'll have to do this to entire car to guarantee full removal of contaminants, and that may take XXX hours to be done. My hourly rate is YYY, so that's ZZZ $ dollars, ZZZ-5% for you that looks a nice person. ;)
I was able to get rid of overspray using only a thorough wash with hyper wash (various foam pre-soaks), then 'scrubbing lightly' with drying towel.
Other time I was able to use a fine grade clay bar... On another situation, I had to use medium grade clay, which left marring that had to be polished out.
The happiest moment in my overspray removal was when I could use nanoskin medium mitt and the overspray was vanished in little passes...
The worst moment was when I needed to sand down sprayed areas to fully get rid of them, any clay and even compounding was able to get rid of it (strange as it looks, that happened!).
I recommend you to clay entire car always you can, majorly on those situations.
I also recommend you to avoid claying / 'nanoskying' (lol) difficult to polish areas, so you may have a hard time removing clay marring.
Overspray is not as trivial as it looks, like I said above, some goes easy, and some may be a real PITH (pain in the head) to remove.
I would like to talk a lot (yet talked!) because this is one of the subjects I like most, I've tried to give you a general idea of how I try to deal with it, so you can take advantage of something to add to your way of doing things.
Hope I've helped,
Kind Regards.
Why would you only do certain panels? Overspray gets EVRYWHERE!!!!
You should have clayed any and all painted surfaces, to Include glass. Did you do the plastic bag test? That's a good way to see how bad a panel is and how clean it's getting.
Claying is like washing a car, you don't just wash the hood or trunk, you wash the whole car.
I would use lacquer thinner or a brand new razorblade on the glass
You guys have all been a great help. I had already rescheduled him to come back in before I talked to you guys. My process was incorrect and I really thank you guys for the enlightenment. I definitely under estimated the over spray removal process. I will be adjusting my business practices accordingly.
Don't forget to use NEW RAZORBLADES
Nothing worse then ruining a window over a 2 cent razorblade
