Overspray remover
C30-Mike
My Camry was in the bodyshop for extensive repair and when all was done it came out great. However, the prep person did a very bad job covering the car that does not need to be painted and the interior as well.
The interior and exterior was covered with overspray. Yes I said interior.
The issue is the roof is very heavy in overspray and I used Wolfgang clay with no results. It was only able to remove overspray from the glass.
I am thinking about buying a more aggressive clay but do not want to resort to "clay block" or Meguiars red clay that may mar the finish. What type clay can I get?
FYI: The overspray I feel is very fine and evenly covered. I can not see it but only feel.
The bodyshop want to have their onsite pro hack detailer fix it. Uh, I will pass on this free offer.
claying and polishing usually do the trick, sometimes you need to clay more than once or move to a more aggressive clay like the Megs that you noted.
I would go over it with a solvent to loosen the overspray up then go over it with a polish. You can even try a plastic razor blade since you will need to polish it anyway. Let's start over-lol, wipe down with a solvent to loosen it up, go over it with a plastic razor blade and then polish what is left of the overspray.
what do you use for a solvent?
Prepsol, Acyrosol, 3M Wax and Adhesive Remover ... Griots has one too.
Thanks for the input.
I am going to try ClayMagic medium grade clay and polish out with SwirlX with a PC.
See how this goes this weekend. I was told any maring the aggrassive clay leaves can be easily removed with a polish and PC.
I just dealt with this very same issue yesterday. My cousin's car got over-sprayed a couple of weeks ago. We tried using clay, but it didn't really remove too much. Then we tried M105 and that removed quite a bit in just one pass with a lot less effort. So I agree with your method. Let us know how it works out.
Other options for solvents for the outside would be,
Lacquer thinner
Mineral Spirits (pretty weak but very safe to try)
Turpentine
Goo-Gone
Goof-Off
Motsenbocker's LIFT OFF 4
For the inside, any place that see high contact like where you sit or arm rests it will wear off, the rest of the surfaces it will be touch to remove it. Maybe stick the body shop with the bill for a brand new interior?
If you're going to have to get so aggressive as to have to use a plastic razor blade then using an aggressive clay bar won't be any more damaging. With either approach you're going to have to re-polish the paint to remove any scuffing, marring or scratching.
This just goes to show that one of the best and most likely places for a car to get overspray is at a body shop, whether it happens when the car is in the paint booth or simply parked in or around the body shop. Body shops spray paint, not always inside the paint booth, thus the potential for air-born overspray paint is high and anything in the area is at risk.
Good luck getting it all off.
