Been there, done that a few times... have a few pictures...
Removing Overspray Paint using Nanoskin Autoscrub Pads
This 1963 Plymouth Fury was recently repainted. As a by-product of the painting process, there was overspray all over the car. It was very easy to feel the overspray paint on the hood and the windshield but chances are very good the
entire car has some level of overspray paint, including all the glass, all the paint, all the chrome and stainless steel trim and even the wheels and tires.
Interesting Factoid...
The most common place to get overspray paint on your car is while it's at a body shop for repairs or a complete paint job.
Tip...
Anytime you have your car re-painted, or even just a portion of the car repainted, while at the body shop, inspect the car for overspray and if discovered, point this out to the shop managers.
Nanosking Autoscrub Pads
This is a cropped out section from the above with no resizing...
Fine and Medium Grade Pads
The blue foam indicates the fine grade while the yellow foam indicates the medium grade Nanoskin Autoscrub Pads.
Nanoskin Glide Instant Detailer and Spray Lubricant Concentrate
Time to get busy....
The Nanoskin Autoscrub pads are incredibly effective at removing above surface bonded contaminants like paint overspray and best of all you work by machine using dual action polishers, any dual action polisher.
Here's Tim using a Meguiar's G110v2 with a Medium Grade, (Yellow), Nanoskin Autoscrub Pad...
Here's Den using a Porter Cable 7424XP with a Medium Grade, (Yellow), Nanoskin Autoscrub Pad...
Here's Greg using a Porter Cable 7424XP with a Nanoskin Autoscrub Medium Grade Pad....
Here's Andy give some pointers literally....
Here's Nick using the Griot's Garage DA Polisher with a Nanoskin Autoscrub Medium Pad...
Here's Craig using the Cyclo Mark 5 Pro with two 4" Nanoskin Autoscrub Medium Grade Pads...
Here's Bryan using the Meguiar's G110v2 with the Nanoskin Autoscrub Fine Grade Pad...
Tim is a machine with a machine! Way to go Tim!
Here's Rob using the Griot's DA Polisher with the Nanoskin Autoscrub Medium Grade Pad...
As you can see, just by this first machine step the gloss is already starting to really amp up!
On Autogeek.net
Nanoskin Car Care Products
:xyxthumbs:
