Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Overview: RUPES NEW D-A Series Compounds and Foam Pads
Recently RUPES sent me the new D-A compounds and pads to test out.
This will be an overview of the products and pads.
My first observation is the nice flashy metallic color matching packaging.
Here's the new pads out of the packaging. RUPES has streamlined their new system to simplify it across all their orbital tool. These new pads and products are designed and formulated to work with all RUPES orbital polishers.
From the manufacturer
BLUE
The DA COARSE foam pad is specially designed to be used with both random orbital and gear-driven tools. The unique open-cell all new foam material removes mild to severe defects from most paint systems. When paired with RUPES DA-COARSE compound provides improved cutting and finishing ability. This new pad combines the best aspects of the previous blue and green foams, with an increased durability and a more vibrant blue color.
My comments...
This is a new foam formula that retains it's aggressive cutting action while finishing out nicer with better durability.
YELLOW
The DA FINE foam pad is the most versatile foam pad in the RUPES BigFoot range, delivering an effective rate of defect removal and capability for high-gloss finishing on most paint systems. Pair with RUPES DA-FINE polishing compound for moderate to fine defect removal, paint refinement, or final finishing after heavy compounding steps. This new pad provides the same great performing foam material as the current random orbital yellow foam, expanded to also work with gear-driven orbitals, just with a more vibrant shade of yellow.
My comments
The foam formula for the new yellow pad is the same consistent performance with just a tweak in the color and of course the new design.
WHITE
The DA ULTRAFINE foam pad is our finest grade of foam, designed for ultra-high gloss finishing and polishing haze-prone or very soft paint surfaces. The new unique material composition of the DA ULTRA-FINE pad shows a brighter white color with less propensity for yellowing over time and can also be used for the application of sealants or waxes when no correction is required. Pair it with UNO PURE ultra-fine universal polish to remove extremely fine defects or to bring out a show car level finish on even the most difficult-to-finish and delicate vehicle paints.
My comments
The new foam formula for the ULTRAFINE white foam finishing pads offers a brighter white that's less prone to yellowing. One of the reason many foams are pigmented is because in the past, white colored foam would quickly turn a dingy yellow or brown color. The pigment used was simply unstable and especially when exposed to UV light. RUPES has somehow found a way to overcome this color flaw so their new foam formula for their white foam pads is dramatically more stable. Besides the color difference, the actual feel of the pad is much softer to the touch and with extended durability.
Pad Specs and pictures
The new RUPES DA Foam Pads come in 3 different sizes (currently), and three different levels of aggressiveness or non-aggressiveness.
Metric and U.S. Standard Pad Diameters
Back in the 1975, President Gerald Ford and his Administration tried to get the U.S. to switch to the metric system but alas the effort failed. So while most of the world uses the metric system for measurement back here in the good old USA we're still using inches.
180mm diameter = 7" or for the OCD 7.09" in U.S. Standard
150mm diameter = 6" or for the OCD 5.9" in U.S. Standard
100mm diameter = 4" or the the OCD 3.94" in U.S. Standard
Pad height or thickness
The new RUPES DA Foam Pads are 25mm in thickness, which is .98" or just call it 1 inch thick.
The first generation RUPES foam pads are 28.5mm thick or about 1 1/8" in U.S. Standard
The new RUPES DA FOAM pads are approximately 3.5mm thinner.
On Autogeek.com
Coming soon!
BLUE
My comments...
YELLOW
My comments
WHITE
My comments
On Autogeek.com
Coming soon!
