Oxi Clean and Microfibers
WRXINXS
I am looking for a little more stain cleaning power when I presoak my microfibers. I have currently been presoaking with BF Microfiber Detergent and then putting them though the wash with more BF Microfiber detergent.
I presoak in 3 gallon buckets of hot water for about 30-60 minutes agitating and rubbing the towels together ever few minutes.
I recently went out and bought some Liquid Oxi Clean Stain Fighter Triple Power "Free" version without any perfumes, dyes or chlorine and also got some Oxi Clean maxforce laundry stain remover. I was hopeing to pretreat stains with the maxforce and then add some of the triple power stain fighter into my presoak bucket with the BF microfiber detergent to help with stains.
My only concern is that I know Microfibers should not be treated with fabric softners or bleach. I called about the two Oxi products that I bought and neither contain fabric softeners but they do contain oxygenated bleach (not chlorine bleach). Would this be ok for the microfibers if it its the oxygenated and not chlorinated form of bleach?
Thanks,
Drew
Oxygenated-bleach is:
-Hydrogen peroxide with some sodium and sometimes carbon added to it to form a:
Compound that releases the hydrogen peroxide when added to water.
-Known as "color-safe" or "all fabric" bleach, since it does not degrade most fabric or strip most colors.
-Recommended to be: 'Tested for colorfastness' before using.
____________________________________________________________________________________________________
If this is the: Liquid Oxi Clean Stain Fighter Triple Power "Free"...you have:
Then this is its MSDS:
http://www.armandhammer.com/PDF/Ingredients/OxiCleanStainFighterTriplePower.pdf
CHURCH & DWIGHT
PRODUCT INGREDIENT DISCLOSURES
PRODUCT: OxiClean Stain Fighter Triple Power
OxiClean Stain Fighter Triple Power Free
INGREDIENTS...(*Not in Free variant)
Water
Alcohols, C12-15, Ethoxylated
Hydrogen Peroxide (INCI)
Sodium Polyacrylate (INCI)
C10-16, Alkylbenzenesulfonic Acid
Linear alykylbenzene sulfonate
Brightner...[Tinopal (Trade Name)]
Fragrance*
Xanthan Gum*...[Sanolin Blue Dye (Trade Name)]
If this the: Oxi Clean maxforce laundry stain remover..you have:
http://www.ahprofessional.com/MSDS/MSDS-1704-OXICLEAN MAX Force Laundry Stain Remover.pdf
CHURCH & DWIGHT
COMPOSITION/INFORMATION ON INGREDIENTS (Chemical)
Ingredient.................(% by Weight)..............CAS Number
Water..............................80-90%......................7732-18-5
Nonionic surfactant.............4-10%......................34398-01-1
Propylene Glycol...................1-5%.........................57-55-6
Enzyme Mixture....................0-2...........................Mixture
(Exempt from OSHA and WHMIS as packaged household consumer products.)
Holy Crap Bob, is your last name Britannica by any chance. I always look forward to reading (and sometime re-reading) your post because you definitely do stimulate the neurons :xyxthumbs:
Im with you. I love to see what information Bob puts out. It truly is fascinating.
Bob, thank you very much for that info. yes those are exactly the two products I bought lol! Still unclear as to whether you think they would be microfiber "safe". I know I need to test dark microfibers for colorfastness and I guess the bleach in these is probably not the bleach they say not to use on microfibers on the "caring for microfibers" on the AG page?
Hi Drew...
I'll go out on a limb here and say that: Although peroxides, sodium percarbonate/perborate are also:
Oxidizing/"bleaching-whitening" agents...
I don't recognize any sodium/calcium-hypochlorite bleaches; or, chlorine bleaches, per se...
In the Oxi-Clean products you've purchased.
However...I will state, unequivocally, that a:
"Colorfastness Test-Spot" will prove to be prudent.
Just as the Mike Phillips' "Test-Spot theme" has shown to be true...And of great value!!
Good Luck with your MF towel soaking/cleaning!!
I have used the granular oxi clean before in the wash with my towels and they came out fine.
I pre-soak all my microfiber towels in the granular oxi clean. I use the Gary Dean method for rinseless washing with ONR or Duragloss w/aquawax. When I finish with a panel I toss the towel in a bucket of hot water and the granular oxi clean. I let them sit an hour and agitate by hand once or twice, then in the washer they go with Blackfire Microfiber Cleaner. No problemo ever and they always come out soft and virtually stain free.
I've tried the "Oxy" based cleaners too as a pre-soak. I have found that for the most part, they do not seem to remove most detailing products - waxes, sealants, trim products or greasy stains. I have found that a dedicated microfiber cleaner works the best.
Hi Drew...
Bob, thanks for the help. I'm going to give it a try. It seems others have had success with Oxi-Clean pre-soaking.:xyxthumbs: I will also test for colorfastness as you had mentioned. I will try the Oxi on cheap microfiber loads first as well.
First off, I really like your avatar!!:props: Also, I am going to add both blackfire microfiber cleaner and Oxi-Clean to the presoak to cover both stain removal and the breakdown of detailing products.
You can pre-soak in an APC such as Meguiars APC or APC+. You will likely already have something similar in your detail supply stock.
Ok I ended up returning the pre-treater because of some negative reviews and now I have:
1. OxiClean® Stain Fighter Triple Power Liquid:
"Fights Stains. Whitens Whites. Brightens Colors."
"Give your wash an incredible boost by adding OxiClean® Stain Fighter Triple Power Liquid to every load. The active oxygen power reaches deep into fabric fibers to quickly and safely break up and remove stains. And the built-in optical brightener works to make whites and colors look their best! Available in Fresh Scent and Free (scent and dye-free) variet"
(I will use this along with BF MF cleaner to presoak my lower quality towels that get really dirty.)
2. OxiClean® Darks & Colors:
"Color-Lock™ enzyme system is tough on stains but gentle on your black, dark & colored fabrics."
"Worried your dark or colored clothing will fade over time or get spots in the wash? OxiClean Darks & Colors has been specially formulated with the Color-Lock™ enzyme system to be tough on stains but gentle on your black, dark and colored fabrics. Chlorine free, color safe, and with no optical brighteners, OxiClean Darks & Colors can be used in every load to get out even your toughest stains!"
(I will use this along with BF MF cleaner to presoak my higher end microfibers. It is extra gentle on darks and colors with no optical brightners.)
Both types are safe on colors you would just need to check for colorfastness with the first one I mentioned. I am going to put the towels though the wash with just BF MF cleaner after the presoak and rinse.
This may be overkill but hey its fun (And I will have some nice mostly stain free towels!)
old thread but i'll just add that i've been using oxi clean powder and micro restore in a washing machine with hot water for years. i let it mix up well on high with the towels, let them soak for a while and double rinse. works fine.
Do they contain any optical brighteners? Does anyone know if they affect your MF towels negatively.
