Mike Phillips,
My car currently looks just like your before picture, only in red. It's a '98 Toyota, and I don't know if it has a single stage paint job or clear coat failure.
Kind of like this Toyota truck?
The truck above is a 1993 Toyota Truck and the owner purchased it new, it's never been painted and the above is the original single stage paint. That means chances are VERY good that you have single stage paint and single stage paint is in my opinion easiest to work on and the most fun.
This car I buffed out last night has a newer single stage paint and the paint is so easy to work with and polishes easily to a real high gloss.
The paint never cracked and pealed, it just faded evenly and slowly over time despite regular cleaning and waxing. I gently polished a small section with some polishing compound and the paint looks good with the oxidation removed, and I expect it to turn out similar to your 'after' photo when I finish polishing the whole car.
Single stage paint is very porous and this means it will dry out and oxidize easily. Maintaining a single stage paint that is on a "Daily Driver" means doing maintenance polishing and waxing more often than a non-porous paint like a modern clear coat.
My question for you is...What did you do to protect the paint after you polished it?
Did you use something like Wolfgang Deep Gloss Paint Sealant or did you get the car clear coated? I imagine just waxing it would not be enough to keep the oxidation away.
thanks,
-Marc
Single stage paints react very well to the polishing oils found in Meguiar's pure polishes. The unique oil base used in these polishes was created by Frank Meguiar Jr. back in 1901 when he introduced his Furniture Cleaner and Furniture Polish.
He found these two products also worked exceedingly well on early automotive paints because early cars were painted with the same coating used in the furniture business, that is Shellac, Varnish and Nitrocellulose Lacquer Paint.
These polishes still work great today on single stage paints.
I just re-posted and extreme makeover I did when I ran the MeguiarsOnline.com forum here,
1960 Ford Ranchero - Extreme Makeover - M105/M205 Tag Team
And it includes clickable links to the products, pads and tools I used.
We can help you restore the paint on your Toyota too but I would suggest you start your own, dedicated thread for your project.
If you're not sure how to "Start your own thread", I have an article for that...
How to start a new thread & How to reply to an existing thread
Here's a good forum to start the thread in...
Auto Detailing 101
:xyxthumbs:
