DFB
- Aug 12, 2019
- 4,594
- 2,366
P&S Absolute Rinse-less Wash Review
Rinse-less washing was never on my radar until I became a member here. I kept seeing others using this wash method, so I began wondering if rinse-less would be a viable option to have in my tool chest. To me, a car was not CLEAN without the use of soap and lot and lots of water. As such, my first attempts at rinse-less included a bottle of ONR and a lot of trepidation. That all changed when I first tried P&S Absolute Rinse-less Wash!
Product Attributes -
While P&S were offering their Epic Water-less wash, they were missing from the rinse-less wash sector. In fact, they were once suggesting their Pearl shampoo would function as a rinse-less, which I don’t think got much traction, and rightfully so. This changed about two years ago when P&S joined the party with a ground-up new rinse-less wash.
Absolute was a co-development with The Rag Company, as such it follows TRC’s preference for polymer rather than surfactant-based rinse-less wash products. The concept here being that the polymers help encapsulate dirt for safe removal, rather than dissolving and emulsifying like a surfactant-based product would. And yes, Absolute will leave behind polymers after use, and no, this won’t alter the characteristic of an LSP.
The biggest advantage P&S Absolute has over the competition is slickness. Now, a product like Carpro ECH20, Gyeon EcoWash or Opti-Coat No Rinse (yellow ONR) would be slicker than Absolute, those products have Si02 and carnauba wax within the formula to provide that effect. On it’s own, Absolute is impressive for what it delivers without laying down some form of “protection” in the process.
Product Notes –
Dilution - P&S Absolute follows the industry standard 256:1 dilution ratio for rinse-less washing. It can also be used for interior cleaning, glass cleaning, clay lubricant, drying aid and as a quick detailer.
Rinse-less Washing – 256:1
Quick Detailer – 64:1
Drying Aid – 64:1
Glass – 256:1
Interior Cleaning – 256:1
Clay Lubricant – 128:1
Mixing – P&S Absolute has a thicker and somewhat gloppy consistency in concentrate form, which led to people shaking the bottle quite vigorously prior to mixing. Anecdotal evidence suggests that this makes it harder to mix into the bucket, the over agitation messing with the polymers. Instead, its recommended to lightly shake/sway the bottle prior to measuring out. I have also noticed warm water helps in this regard too.
One criticism of Absolute, for me at least, is that there is no colorant to help display the product in the mixed solution. As such, I tend to be more thorough than usual when mixing a batch, I also miss the visual confirmation that there is actually something in the water, a hang up from my soap and water method. On the flipside to this, the lack of colorant means you won’t stain your wash media.
Personal Usage Notes -
As mentioned earlier, P&S Absolute is the product that made me comfortable with rinse-less washing. The very first time I used it, I was impressed with the slickness it possessed, both during and after the wash. That and the intoxicating coconut-lime scent. For whatever reason, Absolute just felt “natural”, to the point where it gave me the confidence to try other rinse-less products and lean on the method more than I thought I would.
In my case, I use the multiple towel/Garry Dean method when it comes to rinse-less, but I have also used the foam sponge method as well. And while a drying aid is generally not needed, I do anyway. Speaking of which, the secret sauce when it comes to P&S Absolute is how well it plays with another P&S product, Bead Maker!
On its own, Absolute is slick. But when teamed with a few light sprays of Bead Maker during the drying process, you would be hard pressed to find a glossier, slicker end result. And while I understand that both products have been over-hyped in the past, you can’t argue with the results. Again, that slickness is like a psychological green light for me in trusting and enjoying rinse-less washing.
Final Thoughts -
P&S Absolute in the grand scheme of things is NOT a game changer as it was hyped during its launch. No doubt there are better cleaning rinse-less products, some are slicker, some are easier to mix. What I like about Absolute though is user experience. It starts with the scent, flows through to the slickness while you wash, then rewards with a glossy and slick finish at the end, something that is amplified when teamed up with Bead Maker.
Product Notes –
Drying Aid – 64:1
Glass – 256:1
Final Thoughts -
