It can be used at full strength, or diluted down to clean at another desired intensity.
My concern is that the product description says it's not abrasive...yet also will lift wax buildup! Sounds like it would
remove the LSP that you worked so hard to create!! Feed back please
Whenever I become negatively concerned about a car-care product...I no longer will use it, or buy it.My concern is that the product description says it's not abrasive...yet also will lift wax buildup! Sounds like it would
Sounds like the same road you're getting ready to travel.
It works extremely well on lower areas that are abused thru road dirt and other issues. Spray it on, allow to dwell, and slightly agitate. It will remove waxes and I believe it might be citrus based.
If it removes waxes, then it will remove sealants too?
Not necessarily. It depends which waxes and which sealants.
I have used TAW many times over, and have never had any concerns or regrets. It performs as advertised...straight-up neat, or diluted!Haven't used it yet, but the product description concerned me.
