ronkh57
- Aug 20, 2009
- 3,392
Polish Angel Cosmic Spritz:
Description from AAC Store
POLISHANGEL® | COSMIC SPRITZ is the newly developed maintenance spray for GLASSCOAT™ | COSMIC.
Cosmic Spritz has the highest concentration Silica and Titanium Dioxide of all our spray products. Silica produces an extremely hard durable surface that protects against corrosion. Titanium dioxide provides extreme shine and color transparency.
Cosmic Spritz boosts the hardness of Cosmic. It also contains unique ingredients to reduce the total curing time of Cosmic from 24 hours to 12 hours when applied 1 hour after the final coat of Cosmic. Cosmic Spritz requires only a minimal amount of product to be effective. Cosmic Spritz leaves no residue on the plastic parts. Can be used as a drying aid.
DIRECTIONS
To aid in the curing of Cosmic:
Apply two or more coats of Cosmic. 1-2 hours after the final coat of Cosmic is applied, apply one coat of Cosmic Spritz Total curing time for Cosmic will now be 12 hours from the application of the final coat of Cosmic. General applications:
Shake well before use Spray a very small amount onto the paint surface or into a microfiber towel Wipe until product is spread thin and evenly Remove any remaining residue with a separate microfiber towel
Now I have no "real" coating on car (yet). I have done things like Gyeon Cure, Overcoat, Hydro2, Sonax BSD, but that's it.
Weather today is HOT/HUMID - It's only 84 right now, but driveway faces East, so it always gets sun.
Prep work: - Wash
I sprayed a WW towel with the Spritz and started drying - WOW - Shine and Glow !!!!! Then a final wipe after.
Semi "Merlin shots"
Overall very impressed with the clarity, shine and glow, surprisingly it seemed to add "depth" which is tough on white
DIRECTIONS
Prep work: - Wash
Semi "Merlin shots"
