Christopher.Brown
- Jun 4, 2013
- 439
I wanted to post on a topic that is part of a much longer article i am writing because i feel it is an important paint polishing variable that is seldom discussed. I believe this variable can make anyone more efficient and can increase their average results across the board if optimally performed.
PAD ANGLE
This term discusses how the pad rests on the painted surface.
This would seem a simple and easy task to keep a pad flat upon a surface, but it requires a high level of mental concentration and focused physical energy to achieve. That is difficult enough on flat surfaces, but its infinitely harder to keep consistent on curved or a multi-transitioned area. So some keys points of emphasis are staying supremely focused and patient.
• A main reason for keeping the pad angle level with the paint surface is that when flat a pad has an even level of power dispersed to all portions of the pad, resulting in an even level of polishing power to the entire pad face. Therefore, if pad angle isn’t maximized, then cutting power is diminished instantaneously. This s no good for anyone, especially if just starting a project.
• Secondly, optimal pad angle also allows the machine to move freely throughout its intended path, performing most of the surface leveling power. If the pad is angled on its tip then the machine works on that tip only. In the case of a Dual Orbital; tipping will bog it down and stop the backing plate rotation. Which is a major poo-poo because its a major source of the DA's polishing success.
• Thirdly, A flat pad allows maximum engagement of its surface area with the paint. This minimizes working time on a panel.
Maximum pad surface area benefits include:
• 1] Even dispersal of the buffing liquid over the surface, which allows for max cut.
• 2] Higher lubricity of the working section allows the pad to squeegee away used buffing particulates more effectively so they don’t mix into the pad, marring the paint.
• 3] Maximal Pad Surface Area Recruitment. This is significant because the greater the amount of available pad the greater amount of clean available buffing liquid to work with and less time will be spent cleaning pad of used product and removed paint particulates.
When a pad is tilted even a slight bit, uneven pressure is placed on the pad. This concentrates force into the tilted section touching the paint. This causes two main issues:
• 1] It places an unregulated amount of forced pressure into a concentrated area of the pad, which causes this concentrated area to receive a great deal more of the force of the machine. This concentrated force generates much more heat, increasing the likelihood of a burn through. Also, when the pad is tipped, whatever isn't working on the section is being wasted, greatly decreasing the pads efficiency and life span because the area engaged is being greatly over worked by friction.
• 2] It bogs down the machine, lowering correction power, because an uneven level of cutting force is applied to the paint’s surface. On a rotary this is a DANGEROUS because the forced rotation of the machine keeps the pad moving and the tilt will concentrate all of the force into the tiny region, making for a situation where a burn could happen in an instant. On a DA random orbital machine, tilting a pad too could drastically slow down or completely stop the backing plate rotation, which means very minimal to no cut.
I tried to keep this short and sweet.. but it could be easily analyzed in a 30 page article....
Enjoy
PAD ANGLE
Enjoy
