I've been using Detailer’s Pro Series Polishing Pad Rejuvenator in my pad washer and it works very well...
I did a review on a few products including the pad washer and Pad Rejuvenator....
Im with Bobby as well. I use dedicated products for their intended purpose.
I am using Dawn to clean my pads. Is a pad cleaner worth it, or is it hype. XMT BOGO is reason I ask. Thanks
I agree. If you can afford it, that's the motto to go by.
I think a pad cleaner is worth it. I'm assuming you mean "pad cleaner" like the liquid cleaner, not the bucket looking machine.
I think the BF is the best on here. However, you can get 95% of the results by getting the Wolfgang/DP/Snappy powdered pad cleaner and mixing 1oz in a 32oz spray bottle with water. Just mix it and use it as a spray.
I used to use Dawn and hated it. You can wring the pads out forever and bubbles will keep coming out of the pad. Maybe I'm very picky, but I had to keep doing it until every last bubble of soap came out off the pad. I spent a lot of time using it and often thought I never got all of it out.
For LSPs I soak pads in mineral spirits/IPA mix (50/50) overnight and wring them out in the mixture the next day. Rinse well with water and all of your LSP will be out of the pad.
I have also heard that you can use an apc.....any truth to this?
I have avoided applying wax with a machine because cleaning the pads is such a ROYAL PITA!!!
I know what you mean. Tried getting my black pad clean from M26 paste wax with no luck. I keep "dedicated" pads now, 1 pad per LSP whether wax or sealant.
