termigator
- Feb 5, 2009
- 721
what do you use to clean your pads? Right now, I'm using Dawn detergent and /or Snappy to clean the pads. I have no problems with removing polish from the pads, but removing sealants and waxes are a bear.
The key, I find, is to get them quickly into a bucket with some strong APC in it and let them soak. You don't want them to sit around for a few days and then try to clean them. Dawn PD is about the strongest stuff you can use to break up the wax/sealant. Wear gloves while using it.
Need a refresher. What's Dawn PD?![]()
Thanks for the offer Jay. I would love to get the Grit Guard, but financially it's just not in the cards right now. That's a big snook BTW. How big?
I ordered the grit gaurd pad washer. Should be here by the weekend. I have the same basic question. How do you know when or how often to you clean the pads? I assume that it differs depending on pad density and product being used. What I have been doing is changing pads after each panel.I assume using one pad for an entire car is bad. With that in mind how often should I clean the pad while detailing? Also how do I know when to clean it?
Yes and I think so.Did the above help?
p.s.
Is gunking-up a word?
Yes and I think so.
I was actually doing 4 or 5 buffing cycles before changing pads. Now that I will have a pad cleaner (as of Thurs), I will clean every 2 or 3 buffing cycles.
Honestly that seems like a lot of cleaning, but, I will try it to see if the pads last a little longer.
Follow up question: How many cleanings before you change pads?
