badazta87 said:Is there a reason nobody uses dishsoap to clean pads?
I use Blue Dawn too. Ever since I switched from Zaino to a pc, I found a different use for the Dawn...cleaning the pads! Just agitate the pads in Dawn and rinse.carnut00 said:I use dishsoap and no ill effects here and seems to work fine on stains. I use regular Dawn.
Very difficult to rinse out (all that foam).badazta87 said:Is there a reason nobody uses dishsoap to clean pads?
I would REALLY like to know the answer to that as well!! ????teeks said:how often does eveyone clean/switch pads while they are polishing? i recently got my PC and was using ssr 2.5 seemed like i had to stop very frequently maybe it was just because it was a little too cold out...
supercharged said:Very difficult to rinse out (all that foam).
MikeyC said:Also, I know some manufacturers say that dish soap will deteriorate the glue that holds the velcro onto the foam.
carnut00 said:which manufacturers? I use autogeeks 5.5" pads.
