Pad Colors - Purpose - Newbie Questions
FAA-ATC
Hi, newbie here. Just bought my first PC 7424 and pad kit from Autogeek. Now I don't know which pads to use for what! So, I've tried the search and didn't get the info I'm looking for so I'm asking for help. Do the various color pads denote their purpose, like cutting, polishing, buffing, etc.? And, if so, do the colors hold across manufacturer lines, like orange always means it is to be used for the same purpose, regardless of brand?
I'm looking forward to my first use of my polisher and getting a shine on my new Monterey Red C6. I'm thinking of clay bar then Rejex. Does it require any particular color of pad?
Thanks all!
Never used Rejex so I'm not sure. But if you search on here, there's some threads/post showing what each color pad is for. Just remember some manufacturers have different uses when compared to the same color pad from another company. I highly reccomend the Edge 2K kit, I love that system.
Here's the Pad layout for the Edge System, can't find the uses for pads with other companies but I'm sure somebody else will chime in.
GearHead_1 said:
The Edge 2000 6 Inch DuraFoam Pads are available in the following varieties:
Yellow Cutting Pad This pad is aggressive, and will cut through deep surface marks and swirls. They work well on heavy oxidation and pitted finishes, and will remove wet sand scratches without causing burning. 50 pores per inch (ppi)
Green Medium Cutting Pad This pad is useful for light oxidation and moderate to severe swirls and imperfections. This pad will yield amazing results on older vehicles, and should be used on vehicles with moderate swirls and imperfections. Add a compound or pre-wax cleaner for a flawless finish on base coats. 60 pores per inch (ppi)
Orange Light Cutting Pad This pad is highly versatile, as it can be used on cars with light to moderate swirls and imperfections. We recommend you begin with this pad if you are unsure how deep swirls are, moving up to a Green Medium Cut Pad if necessary. Safe on clear coats. 65 pores per inch (ppi)
Blue Finishing Pad This pad is great for everyday use. It will leave surface areas scratch-free and smooth while still removing light swirls and imperfections. Use with wax and polish to apply a fine gloss. Safe on clear coats. 70 pores per inch (ppi)
White Ultrafine Polishing Pad This ultra-smooth polishing pad contains 80 pores per inch, allowing for fine polishing which creates a bold, crystalline gloss Use this pad to apply waxes, polishes and sealants. Safe on clear coats. 80 pores per inch (ppi)
Need to know pad kit to offer advice ... Megs, Lake Country, and Edge all follow different coloring for different stages.
If you are using Rejex on your Vette, and want to use your buffer, then use a finishing pad.
These are the most popular pads currently : (made via Lake Country)
Lake Country Pads
Thanks for the replies! I bought my kit from Autogeek and it was the PC 7424 and pad bundle. It has orange, dark gray/black, and white foam pads. I don't know the manufacturer. I'm assuming it matches the chart posted above so I'll go with that unless somebody advises differently. Thanks everybody!
Also, I don't have to use Rejex. If there is another recommendation for use with the PC 7424 then please let me know. I have rheumatioid arthritis and it is the main reason I got the buffer/polisher. My elbows can't take doing a whole car by hand.
Thanks again for your replies. :applause:
I think you got the Wolfgang pad kit.
Orange-light cutting pad
White-polishing pad
Grey-finishing pad
