I have the latest PC 7424XP. I barely apply any force and it just stops. And I never have any problems with soft pads for some reason.
Hi guys! I've had a problem with my orange cutting pad... For some reason whenever I start buffing (usually on speed 5-6) the pad likes to stop whenever I apply VERY little downward force. I find this extremely irritating. Any suggestions?
It is just my opinion, but when I use a random orbital polisher, the jiggling motion gets most of the work done, and the pad doesn't necessarily have to rotate.
If that works for you then that's all that's important.
As for me I want to see the pad rotating and thus pushing or moving the abrasives over and against the paint, not just jiggling against it. If I'm using a DA to remove swirls that means I'm using a DA to remove paint and again, jut my opinion but abrasives being moved against, (that's downward pressure), and over, (that's rotating, not jiggling), the paint is going to remove a little paint faster and more effectively.
Kind of like if i take my hand and work and abrasive product over the paint I move my hand over the paint with pressure, I'm not sure how far I would get to put the applicator pad on the paint and then jiggle or vibrate it.
Actually, when people join forums and ask if they can use their wood sander in place of a Porter Cable 7424 I always tell them it won't work because while it's the same type of tool as a PC in that they are for sanding wood, most all DA Wood Sanders except the PC just vibrate the pad because they don't have the power or ability to make the pad rotate.
Some then try and use their wood sanders to remove swirls but if memory serves me correctly, in every thread on the subject the person with the wood sander ends up giving up on their wood sander and buys a PC style polisher.
One more thing just came to mind, the first DA Polisher Griot's introduced was a wood sander and the number one complaint everyone had about it was that it would not remove swirls and the problem was that it couldn't rotate a pad under pressure... just jiggle it...
Point 100% well taken.
I was hesitant about even posting that, given your recommendations about rotation, and drawing a line on the pad etc., but I guess @ the end of the day, whatever gets the job done!.
